Saltar al contenido principal
iPad Air 2 Wi-Fi Power Button Assembly Replacement
Qué necesitas
  1. iPad Air 2 Wi-Fi Power Button Assembly Replacement, iOpener Heating: paso 1, imagen 1 de 2 iPad Air 2 Wi-Fi Power Button Assembly Replacement, iOpener Heating: paso 1, imagen 2 de 2
    • We recommend that you clean your microwave before proceeding, as any nasty gunk on the bottom may end up stuck to the iOpener.
    • Place the iOpener in the center of the microwave.
    • For carousel microwaves: Make sure the plate spins freely. If your iOpener gets stuck, it may overheat and burn.
  2. iPad Air 2 Wi-Fi Power Button Assembly Replacement: paso 2, imagen 1 de 1
    • Heat the iOpener for thirty seconds.
    • Throughout the repair procedure, as the iOpener cools, reheat it in the microwave for an additional thirty seconds at a time.
    • Be careful not to overheat the iOpener during the repair. Overheating may cause the iOpener to burst. Do not attempt to heat over 100˚C (212˚F).
    • Never touch the iOpener if it appears swollen.
    • If the iOpener is still too hot in the middle to touch, continue using it while waiting for it to cool down some more before reheating. A properly heated iOpener should stay warm for up to 10 minutes.
  3. iPad Air 2 Wi-Fi Power Button Assembly Replacement: paso 3, imagen 1 de 1
    • Remove the iOpener from the microwave, holding it by one of the two flat ends to avoid the hot center.
    • The iOpener will be very hot, so be careful when handling it. Use an oven mitt if necessary.
  4. iPad Air 2 Wi-Fi Power Button Assembly Replacement, Alternate iOpener heating method: paso 4, imagen 1 de 2 iPad Air 2 Wi-Fi Power Button Assembly Replacement, Alternate iOpener heating method: paso 4, imagen 2 de 2
    • If you don't have a microwave, follow this step to heat your iOpener in boiling water.
    • Fill a pot or pan with enough water to fully submerge an iOpener.
    • Heat the water to a boil. Turn off the heat.
    • Place an iOpener into the hot water for 2-3 minutes. Make sure the iOpener is fully submerged in the water.
    • Use tongs to extract the heated iOpener from the hot water.
    • Thoroughly dry the iOpener with a towel.
    • The iOpener will be very hot, so be careful to hold it only by the end tabs.
    • Your iOpener is ready for use! If you need to reheat the iOpener, heat the water to a boil, turn off the heat, and place the iOpener in the water for 2-3 minutes.
  5. iPad Air 2 Wi-Fi Power Button Assembly Replacement, iPad Air 2 Wi-Fi  Opening Procedure: paso 5, imagen 1 de 3 iPad Air 2 Wi-Fi Power Button Assembly Replacement, iPad Air 2 Wi-Fi  Opening Procedure: paso 5, imagen 2 de 3 iPad Air 2 Wi-Fi Power Button Assembly Replacement, iPad Air 2 Wi-Fi  Opening Procedure: paso 5, imagen 3 de 3
    • Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered.
    • Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
    • Wear safety glasses to protect your eyes, and be careful not to damage the LCD screen.
  6. iPad Air 2 Wi-Fi Power Button Assembly Replacement: paso 6, imagen 1 de 1
    • The following steps involve using an iOpener to soften the adhesive holding the front panel assembly in place. When using the iOpener, be sure to heat it in the microwave for no more than 30 seconds.
    • Handling it by the tabs on either end, place a heated iOpener over the top edge of the iPad.
    • Let the iOpener sit on the iPad for two minutes to soften the adhesive securing the front panel to the rest of the iPad.
  7. iPad Air 2 Wi-Fi Power Button Assembly Replacement: paso 7, imagen 1 de 3 iPad Air 2 Wi-Fi Power Button Assembly Replacement: paso 7, imagen 2 de 3 iPad Air 2 Wi-Fi Power Button Assembly Replacement: paso 7, imagen 3 de 3
    • While the iPad looks uniform from the outside, there are delicate components under certain portions of the front glass. To avoid damage, only heat and pry in the areas described in each step.
    • As you follow the directions, take special care to avoid prying in the following areas:
    • Home Button
    • Front Facing Camera
    • Main Camera
  8. iPad Air 2 Wi-Fi Power Button Assembly Replacement, Anti-Clamp instructions: paso 8, imagen 1 de 3 iPad Air 2 Wi-Fi Power Button Assembly Replacement, Anti-Clamp instructions: paso 8, imagen 2 de 3 iPad Air 2 Wi-Fi Power Button Assembly Replacement, Anti-Clamp instructions: paso 8, imagen 3 de 3
    Herramienta utilizada en este paso:
    Anti-Clamp
    $24.95
    Comprar
    • The next two steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down two steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Elevate the iPad enough for the Anti-Clamp's arms to rest above and below the screen.
    • Pull the blue handle towards the hinge to disengage opening mode.
    • Position the suction cups near the top edge of the iPad—one on the front, and one on the back.
    • Push down on the cups to apply suction to the desired area.
    • If you find that the surface of your device is too slippery for the Anti-Clamp to hold onto, you can use packing tape to create a grippier surface.
  9. iPad Air 2 Wi-Fi Power Button Assembly Replacement: paso 9, imagen 1 de 3 iPad Air 2 Wi-Fi Power Button Assembly Replacement: paso 9, imagen 2 de 3 iPad Air 2 Wi-Fi Power Button Assembly Replacement: paso 9, imagen 3 de 3
    • Push the blue handle away from the hinge to engage opening mode.
    • Turn the handle clockwise until you see the cups start to stretch.
    • Make sure the suction cups remain aligned to each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
    • Don't crank more than a half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next two steps.
  10. iPad Air 2 Wi-Fi Power Button Assembly Replacement: paso 10, imagen 1 de 2 iPad Air 2 Wi-Fi Power Button Assembly Replacement: paso 10, imagen 2 de 2
    • Place a suction cup over the iPad's front-facing camera and press down to create a seal.
    • To get the most leverage, place the suction cup as close to the edge as possible without going past the edge of the display.
  11. iPad Air 2 Wi-Fi Power Button Assembly Replacement: paso 11, imagen 1 de 3 iPad Air 2 Wi-Fi Power Button Assembly Replacement: paso 11, imagen 2 de 3 iPad Air 2 Wi-Fi Power Button Assembly Replacement: paso 11, imagen 3 de 3
    • Firmly pull up on the suction cup to create a small gap between the front panel and the rear case.
    • Do not pull too hard or you may shatter the glass.
    • Once you've opened a sufficient gap, insert an opening pick into the gap to prevent the adhesive from resealing.
  12. iPad Air 2 Wi-Fi Power Button Assembly Replacement: paso 12, imagen 1 de 3 iPad Air 2 Wi-Fi Power Button Assembly Replacement: paso 12, imagen 2 de 3 iPad Air 2 Wi-Fi Power Button Assembly Replacement: paso 12, imagen 3 de 3
    • Slide the pick along the edge of the display, towards the headphone jack.
    • If there is still a considerable amount of resistance when sliding the opening pick, repeat the iOpener heating procedure and apply additional heat.
    • Be careful not to let the opening pick slide between the fused LCD and front panel, as doing so can permanently damage the display.
    • A good rule of thumb is to never insert the opening pick more than a quarter inch (6 mm) into the iPad.
  13. iPad Air 2 Wi-Fi Power Button Assembly Replacement: paso 13, imagen 1 de 2 iPad Air 2 Wi-Fi Power Button Assembly Replacement: paso 13, imagen 2 de 2
    • Insert a second opening pick by the front-facing camera.
  14. iPad Air 2 Wi-Fi Power Button Assembly Replacement: paso 14, imagen 1 de 3 iPad Air 2 Wi-Fi Power Button Assembly Replacement: paso 14, imagen 2 de 3 iPad Air 2 Wi-Fi Power Button Assembly Replacement: paso 14, imagen 3 de 3
    • Slide the second pick along the top edge of the iPad, towards the Sleep/Wake Button.
  15. iPad Air 2 Wi-Fi Power Button Assembly Replacement: paso 15, imagen 1 de 2 iPad Air 2 Wi-Fi Power Button Assembly Replacement: paso 15, imagen 2 de 2
    • Insert a third pick by the front-facing camera.
  16. iPad Air 2 Wi-Fi Power Button Assembly Replacement: paso 16, imagen 1 de 3 iPad Air 2 Wi-Fi Power Button Assembly Replacement: paso 16, imagen 2 de 3 iPad Air 2 Wi-Fi Power Button Assembly Replacement: paso 16, imagen 3 de 3
    • Bring the right opening pick down and around the top right corner of the iPad.
  17. iPad Air 2 Wi-Fi Power Button Assembly Replacement: paso 17, imagen 1 de 3 iPad Air 2 Wi-Fi Power Button Assembly Replacement: paso 17, imagen 2 de 3 iPad Air 2 Wi-Fi Power Button Assembly Replacement: paso 17, imagen 3 de 3
    • Bring the left opening pick around the top left corner of the tablet.
  18. iPad Air 2 Wi-Fi Power Button Assembly Replacement: paso 18, imagen 1 de 1
    • Reheat the iOpener and lay it over the right edge of the display to loosen the adhesive underneath.
  19. iPad Air 2 Wi-Fi Power Button Assembly Replacement: paso 19, imagen 1 de 3 iPad Air 2 Wi-Fi Power Button Assembly Replacement: paso 19, imagen 2 de 3 iPad Air 2 Wi-Fi Power Button Assembly Replacement: paso 19, imagen 3 de 3
    • Slide the right opening pick roughly halfway down the display.
  20. iPad Air 2 Wi-Fi Power Button Assembly Replacement: paso 20, imagen 1 de 1
    • Reheat the iOpener and apply heat to the left side of the iPad.
  21. iPad Air 2 Wi-Fi Power Button Assembly Replacement: paso 21, imagen 1 de 3 iPad Air 2 Wi-Fi Power Button Assembly Replacement: paso 21, imagen 2 de 3 iPad Air 2 Wi-Fi Power Button Assembly Replacement: paso 21, imagen 3 de 3
    • Slide the left-hand opening pick about halfway down the edge of the display.
  22. iPad Air 2 Wi-Fi Power Button Assembly Replacement: paso 22, imagen 1 de 3 iPad Air 2 Wi-Fi Power Button Assembly Replacement: paso 22, imagen 2 de 3 iPad Air 2 Wi-Fi Power Button Assembly Replacement: paso 22, imagen 3 de 3
    • Slide the opposite opening pick down to the bottom right corner of the iPad.
    • If necessary, reheat the adhesive on the right edge to loosen the display assembly.
  23. iPad Air 2 Wi-Fi Power Button Assembly Replacement: paso 23, imagen 1 de 3 iPad Air 2 Wi-Fi Power Button Assembly Replacement: paso 23, imagen 2 de 3 iPad Air 2 Wi-Fi Power Button Assembly Replacement: paso 23, imagen 3 de 3
    • Slide the left-hand opening pick down the edge of the display until you reach the corner.
  24. iPad Air 2 Wi-Fi Power Button Assembly Replacement: paso 24, imagen 1 de 1
    • Use the iOpener to apply heat to the bottom edge of the iPad.
  25. iPad Air 2 Wi-Fi Power Button Assembly Replacement: paso 25, imagen 1 de 3 iPad Air 2 Wi-Fi Power Button Assembly Replacement: paso 25, imagen 2 de 3 iPad Air 2 Wi-Fi Power Button Assembly Replacement: paso 25, imagen 3 de 3
    • Bring the right-hand opening pick around the bottom corner of the iPad.
  26. iPad Air 2 Wi-Fi Power Button Assembly Replacement: paso 26, imagen 1 de 3 iPad Air 2 Wi-Fi Power Button Assembly Replacement: paso 26, imagen 2 de 3 iPad Air 2 Wi-Fi Power Button Assembly Replacement: paso 26, imagen 3 de 3
    • Repeat for the left-hand pick.
    • Reheat and reapply the iOpener as needed. Always wait at least ten minutes before reheating the iOpener.
  27. iPad Air 2 Wi-Fi Power Button Assembly Replacement: paso 27, imagen 1 de 2 iPad Air 2 Wi-Fi Power Button Assembly Replacement: paso 27, imagen 2 de 2
    • Remove the right-hand opening pick at the bottom of the iPad.
  28. iPad Air 2 Wi-Fi Power Button Assembly Replacement: paso 28, imagen 1 de 3 iPad Air 2 Wi-Fi Power Button Assembly Replacement: paso 28, imagen 2 de 3 iPad Air 2 Wi-Fi Power Button Assembly Replacement: paso 28, imagen 3 de 3
    • Slide the left-hand opening pick along the bottom edge of the display, then remove it from the bottom right corner of the iPad.
    • Be very careful to not insert the pick more than 2 mm below home button to avoid damaging the button.
    • Be very careful to not insert the pick more than a quarter inch (6 mm) into either side of the home button to avoid damaging the display cables underneath.
  29. iPad Air 2 Wi-Fi Power Button Assembly Replacement: paso 29, imagen 1 de 3 iPad Air 2 Wi-Fi Power Button Assembly Replacement: paso 29, imagen 2 de 3 iPad Air 2 Wi-Fi Power Button Assembly Replacement: paso 29, imagen 3 de 3
    • Twist the remaining pick by the front-facing camera to separate the top edge of the display assembly from the rear case.
  30. iPad Air 2 Wi-Fi Power Button Assembly Replacement: paso 30, imagen 1 de 3 iPad Air 2 Wi-Fi Power Button Assembly Replacement: paso 30, imagen 2 de 3 iPad Air 2 Wi-Fi Power Button Assembly Replacement: paso 30, imagen 3 de 3
    • Continue lifting the display assembly from the front-facing camera side.
    • Pull the display slightly away from the bottom edge to completely separate it from the rear case.
    • Keep lifting until the display assembly is roughly perpendicular to the body of the iPad.
    • Do not attempt to remove the display yet—it is still attached to the rear case by three delicate ribbon cables.
  31. iPad Air 2 Wi-Fi Power Button Assembly Replacement: paso 31, imagen 1 de 1
    • Remove the single 1.8 mm Phillips screw securing the battery terminals to their contacts on the logic board.
  32. iPad Air 2 Wi-Fi Power Button Assembly Replacement, Battery connector information: paso 32, imagen 1 de 3 iPad Air 2 Wi-Fi Power Button Assembly Replacement, Battery connector information: paso 32, imagen 2 de 3 iPad Air 2 Wi-Fi Power Button Assembly Replacement, Battery connector information: paso 32, imagen 3 de 3
    • These photos show what the battery connector looks like underneath the logic board. Use these photos as a reference while you safely disconnect the battery.
    • Notice that the battery connector has springs on the logic board that press down against the battery contact pads. You'll need to slide something thin and flexible between the contact points to disconnect the battery.
  33. iPad Air 2 Wi-Fi Power Button Assembly Replacement: paso 33, imagen 1 de 2 iPad Air 2 Wi-Fi Power Button Assembly Replacement: paso 33, imagen 2 de 2
    • To reduce the risk of a short, you can use a battery isolation pick to disconnect the battery.
    • Be very careful when you isolate the battery using a battery blocker. The battery contacts are easily damaged, resulting in irreversible damage to the logic board.
    • Slide a battery isolation pick underneath the battery connector area of the logic board, and leave it in place while you work.
    • Alternatively, make a battery blocker using a playing card and slide it underneath the logic board connector to disconnect the battery.
  34. iPad Air 2 Wi-Fi Power Button Assembly Replacement: paso 34, imagen 1 de 3 iPad Air 2 Wi-Fi Power Button Assembly Replacement: paso 34, imagen 2 de 3 iPad Air 2 Wi-Fi Power Button Assembly Replacement: paso 34, imagen 3 de 3
    • Remove the three 1.3mm Phillips screws from the display cable bracket.
    • Remove the bracket.
  35. iPad Air 2 Wi-Fi Power Button Assembly Replacement: paso 35, imagen 1 de 2 iPad Air 2 Wi-Fi Power Button Assembly Replacement: paso 35, imagen 2 de 2
    • Disconnect the display data connector from its socket on the logic board.
  36. iPad Air 2 Wi-Fi Power Button Assembly Replacement: paso 36, imagen 1 de 3 iPad Air 2 Wi-Fi Power Button Assembly Replacement: paso 36, imagen 2 de 3 iPad Air 2 Wi-Fi Power Button Assembly Replacement: paso 36, imagen 3 de 3
    • Disconnect the two remaining digitizer cables underneath the display data cable.
  37. iPad Air 2 Wi-Fi Power Button Assembly Replacement: paso 37, imagen 1 de 1
    • Remove the front panel assembly from the rear case.
    • If you plan to reuse your display assembly, you will need to replace the display adhesive. Follow our iPad Adhesive Guide to reapply your display adhesive and reseal your device.
  38. iPad Air 2 Wi-Fi Power Button Assembly Replacement, Upper Component Cable Bracket: paso 38, imagen 1 de 3 iPad Air 2 Wi-Fi Power Button Assembly Replacement, Upper Component Cable Bracket: paso 38, imagen 2 de 3 iPad Air 2 Wi-Fi Power Button Assembly Replacement, Upper Component Cable Bracket: paso 38, imagen 3 de 3
    • Remove the following four Phillips screws securing the upper component cable bracket to the tablet.
    • Two 1.6 mm
    • Two 1.3 mm
    • Slide the upper component cable bracket out from under the protective flaps and remove it from the iPad.
  39. iPad Air 2 Wi-Fi Power Button Assembly Replacement, Rear-Facing Camera: paso 39, imagen 1 de 3 iPad Air 2 Wi-Fi Power Button Assembly Replacement, Rear-Facing Camera: paso 39, imagen 2 de 3 iPad Air 2 Wi-Fi Power Button Assembly Replacement, Rear-Facing Camera: paso 39, imagen 3 de 3
    • Use the flat end of a spudger to disconnect the iSight camera from its socket on the logic board.
    • Remove the iSight camera.
  40. iPad Air 2 Wi-Fi Power Button Assembly Replacement, Power Button Assembly: paso 40, imagen 1 de 3 iPad Air 2 Wi-Fi Power Button Assembly Replacement, Power Button Assembly: paso 40, imagen 2 de 3 iPad Air 2 Wi-Fi Power Button Assembly Replacement, Power Button Assembly: paso 40, imagen 3 de 3
    • Remove the single 2.3 mm Phillips screw holding the plastic microphone bracket in place.
    • Remove the microphone bracket.
  41. iPad Air 2 Wi-Fi Power Button Assembly Replacement: paso 41, imagen 1 de 2 iPad Air 2 Wi-Fi Power Button Assembly Replacement: paso 41, imagen 2 de 2
    • Use the flat end of a spudger to pry up the power button/microphone ribbon cable connector from its socket.
  42. iPad Air 2 Wi-Fi Power Button Assembly Replacement: paso 42, imagen 1 de 1
    • Place a heated iOpener on the top left corner of the back of the iPad.
    • Let the iOpener sit for at least a minute to soften the adhesive securing the microphone ribbon cable to the rear case.
  43. iPad Air 2 Wi-Fi Power Button Assembly Replacement: paso 43, imagen 1 de 2 iPad Air 2 Wi-Fi Power Button Assembly Replacement: paso 43, imagen 2 de 2
    • Use an opening pick to pry up the microphone ribbon cable from the adhesive securing it to the rear case.
    • If you find that the opening pick isn't effective against the adhesive, use tweezers to pry the cable up.
  44. iPad Air 2 Wi-Fi Power Button Assembly Replacement: paso 44, imagen 1 de 1
    • Remove the two 1.9 mm Phillips screws securing the power button assembly to the rear case.
  45. iPad Air 2 Wi-Fi Power Button Assembly Replacement: paso 45, imagen 1 de 2 iPad Air 2 Wi-Fi Power Button Assembly Replacement: paso 45, imagen 2 de 2
    • Remove the power button assembly.
  46. iPad Air 2 Wi-Fi Power Button Assembly Replacement: paso 46, imagen 1 de 3 iPad Air 2 Wi-Fi Power Button Assembly Replacement: paso 46, imagen 2 de 3 iPad Air 2 Wi-Fi Power Button Assembly Replacement: paso 46, imagen 3 de 3
    • Only perform the following steps if you intend to replace the power button ribbon cable, as shown in our store here: iPad Air 2 Power Button Assembly. If you do not need to detach the cable from the rest of assembly, skip the next 3 steps.
    • Peel the ribbon cable with the microphone up from the plastic bracket.
  47. iPad Air 2 Wi-Fi Power Button Assembly Replacement: paso 47, imagen 1 de 2 iPad Air 2 Wi-Fi Power Button Assembly Replacement: paso 47, imagen 2 de 2
    • Flip the assembly over and peel up the black rubber piece covering the portion of the ribbon cable with the ambient light sensor.
  48. iPad Air 2 Wi-Fi Power Button Assembly Replacement: paso 48, imagen 1 de 2 iPad Air 2 Wi-Fi Power Button Assembly Replacement: paso 48, imagen 2 de 2
    • Pry up the ribbon cable with the ambient light sensor from the plastic bracket.
    • Remove the ribbon cable.
  49. iPad Air 2 Wi-Fi Power Button Assembly Replacement: paso 49, imagen 1 de 2 iPad Air 2 Wi-Fi Power Button Assembly Replacement: paso 49, imagen 2 de 2
    • Use a spudger to press the power button into the iPad and remove it.
Conclusión
9 personas más completaron esta guía.
Paige Reisman
Miembro Desde 04/07/14
23,604 Reputación
15 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 27
Ultimos 30 días: 110
Todo El Tiempo: 20,477
