Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 18 guías que incluyan este paso.
Inglés
Español
Paso 5
Firmly pull up on the suction cup to create a small gap between the front panel and the rear case. Do not pull too hard or you may shatter the glass. Once you've opened a sufficient gap, insert an opening pick into the gap to prevent the adhesive from resealing.
  • Firmly pull up on the suction cup to create a small gap between the front panel and the rear case.
  • Do not pull too hard or you may shatter the glass.
  • Once you've opened a sufficient gap, insert an opening pick into the gap to prevent the adhesive from resealing.
Levanta firmemente la ventosa para crear una pequeña brecha entre el panel frontal y la carcasa posterior.
No tires muy fuerte o podrías romper el vidrio.
Cuando hayas abierto una brecha suficiente, inserta una púa de apertura dentro de la brecha para prevenir que el adhesivo vuelva a sellarse.
-[* black] Firmly pull up on the suction cup to to create a small gap between the front panel and the rear case.
+[* black] Firmly pull up on the suction cup to create a small gap between the front panel and the rear case.
[* icon_caution] Do not pull too hard or you may shatter the glass.
[* black] Once you've opened a sufficient gap, insert an opening pick into the gap to prevent the adhesive from resealing.
