Saltar al contenido principal
MacBook Pro 16" 2021 USB-C Ports Replacement
Qué necesitas
  1. MacBook Pro 16" 2021 USB-C Ports Replacement, Unfasten the lower case: paso 1, imagen 1 de 2 MacBook Pro 16" 2021 USB-C Ports Replacement, Unfasten the lower case: paso 1, imagen 2 de 2
    Herramienta utilizada en este paso:
    Magnetic Project Mat
    $19.95
    Comprar
    • Completely power off and unplug your MacBook Pro before you start. Close the display and flip the entire laptop upside-down.
    • Use a P5 Pentalobe driver to remove eight screws securing the lower case:
    • Four 9.1 mm screws
    • Four 5 mm screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  2. MacBook Pro 16" 2021 USB-C Ports Replacement, Unclip the lower case: paso 2, imagen 1 de 2 MacBook Pro 16" 2021 USB-C Ports Replacement, Unclip the lower case: paso 2, imagen 2 de 2
    • Press a suction handle into place near the front edge of the lower case, between the screw holes.
    • Pull up on the suction handle to create a small gap under the lower case.
  3. MacBook Pro 16" 2021 USB-C Ports Replacement, Release the rear cover's right clips: paso 3, imagen 1 de 3 MacBook Pro 16" 2021 USB-C Ports Replacement, Release the rear cover's right clips: paso 3, imagen 2 de 3 MacBook Pro 16" 2021 USB-C Ports Replacement, Release the rear cover's right clips: paso 3, imagen 3 de 3
    • Insert an opening pick into the gap you just created.
    • Slide the opening pick around the nearest corner and then halfway up the side of the MacBook Pro.
    • This releases the first of the hidden clips securing the lower case. You should feel and hear the clip pop free.
  4. MacBook Pro 16" 2021 USB-C Ports Replacement, Release the rear cover's left clips: paso 4, imagen 1 de 3 MacBook Pro 16" 2021 USB-C Ports Replacement, Release the rear cover's left clips: paso 4, imagen 2 de 3 MacBook Pro 16" 2021 USB-C Ports Replacement, Release the rear cover's left clips: paso 4, imagen 3 de 3
    • Repeat the previous step on the other side, using an opening pick to to release the second clip.
  5. MacBook Pro 16" 2021 USB-C Ports Replacement: paso 5, imagen 1 de 3 MacBook Pro 16" 2021 USB-C Ports Replacement: paso 5, imagen 2 de 3 MacBook Pro 16" 2021 USB-C Ports Replacement: paso 5, imagen 3 de 3
    • Pull firmly to slide the lower case towards the front edge of the MacBook (away from the hinge area) to separate the last of the clips securing the lower case.
    • Pull first at one corner, then the other.
    • Pull to the side—not up.
    • This may require a lot of force.
  6. MacBook Pro 16" 2021 USB-C Ports Replacement, Remove the lower case: paso 6, imagen 1 de 3 MacBook Pro 16" 2021 USB-C Ports Replacement, Remove the lower case: paso 6, imagen 2 de 3 MacBook Pro 16" 2021 USB-C Ports Replacement, Remove the lower case: paso 6, imagen 3 de 3
    • Remove the lower case.
    • To reinstall the lower case:
    • Set it in place and align the sliding clips near the display hinge. Press down and slide the cover toward the hinge. It should stop sliding as the clips engage.
    • When the sliding clips are fully engaged and the lower case looks correctly aligned, press down firmly on the lower case to engage the four hidden clips underneath. You should feel and hear them snap into place.
  7. Aviso: los pasos 7-19 provienen de una guía que está marcada como "En progreso".
    MacBook Pro 16" 2021 USB-C Ports Replacement, Disconnect the battery board: paso 7, imagen 1 de 3 MacBook Pro 16" 2021 USB-C Ports Replacement, Disconnect the battery board: paso 7, imagen 2 de 3 MacBook Pro 16" 2021 USB-C Ports Replacement, Disconnect the battery board: paso 7, imagen 3 de 3
    • Peel back any tape covering the battery board data cable connector on the logic board.
  8. MacBook Pro 16" 2021 USB-C Ports Replacement: paso 8, imagen 1 de 2 MacBook Pro 16" 2021 USB-C Ports Replacement: paso 8, imagen 2 de 2
    • Use a spudger to gently pry up the locking flap on the ZIF connector for the battery board data cable.
  9. MacBook Pro 16" 2021 USB-C Ports Replacement: paso 9, imagen 1 de 2 MacBook Pro 16" 2021 USB-C Ports Replacement: paso 9, imagen 2 de 2
    • Disconnect the battery board data cable by sliding it out from its socket on the logic board.
  10. MacBook Pro 16" 2021 USB-C Ports Replacement, Unfasten the trackpad cable bracket: paso 10, imagen 1 de 1
    • Use a T3 Torx driver to remove the two 2.1 mm‑long screws securing the trackpad cable bracket to the logic board.
  11. MacBook Pro 16" 2021 USB-C Ports Replacement, Remove the trackpad cable bracket: paso 11, imagen 1 de 2 MacBook Pro 16" 2021 USB-C Ports Replacement, Remove the trackpad cable bracket: paso 11, imagen 2 de 2
    Comprar
    • Use tweezers, or your fingers, to remove the trackpad cable bracket.
  12. MacBook Pro 16" 2021 USB-C Ports Replacement, Disconnect the trackpad cable: paso 12, imagen 1 de 2 MacBook Pro 16" 2021 USB-C Ports Replacement, Disconnect the trackpad cable: paso 12, imagen 2 de 2
    • Use the flat end of a spudger to pry up and disconnect the trackpad cable's press connector from the logic board.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  13. MacBook Pro 16" 2021 USB-C Ports Replacement, Reposition the trackpad cable: paso 13, imagen 1 de 2 MacBook Pro 16" 2021 USB-C Ports Replacement, Reposition the trackpad cable: paso 13, imagen 2 de 2
    • The trackpad cable is lightly adhered to the frame.
    • Peel the trackpad cable away from the device, making sure to separate the adhesive.
  14. MacBook Pro 16" 2021 USB-C Ports Replacement, Disconnect the battery board: paso 14, imagen 1 de 2 MacBook Pro 16" 2021 USB-C Ports Replacement, Disconnect the battery board: paso 14, imagen 2 de 2
    • Peel back any tape covering the battery board data cable connector under the large pancake screw.
  15. MacBook Pro 16" 2021 USB-C Ports Replacement: paso 15, imagen 1 de 2 MacBook Pro 16" 2021 USB-C Ports Replacement: paso 15, imagen 2 de 2
  16. MacBook Pro 16" 2021 USB-C Ports Replacement: paso 16, imagen 1 de 2 MacBook Pro 16" 2021 USB-C Ports Replacement: paso 16, imagen 2 de 2
    • Disconnect the battery board data cable by sliding it out from its socket on the battery board.
  17. MacBook Pro 16" 2021 USB-C Ports Replacement, Remove the data cable: paso 17, imagen 1 de 2 MacBook Pro 16" 2021 USB-C Ports Replacement, Remove the data cable: paso 17, imagen 2 de 2
    • The battery board data cable is lightly adhered to the device.
    • Slide blunt nose tweezers under areas with adhesive to separate the cable from the device.
    • Remove the battery board data cable.
  18. MacBook Pro 16" 2021 USB-C Ports Replacement, Unfasten the battery connector: paso 18, imagen 1 de 1
    • Use a T5 Torx driver to remove the 3.9 mm pancake screw securing the battery power connector.
  19. MacBook Pro 16" 2021 USB-C Ports Replacement, Disconnect the battery connector: paso 19, imagen 1 de 2 MacBook Pro 16" 2021 USB-C Ports Replacement, Disconnect the battery connector: paso 19, imagen 2 de 2
    • Use a spudger to lift the battery power connector, disconnecting the battery.
    • Lift the connector high enough to keep it separated from its socket while you work. If it accidentally makes contact, it could damage your MacBook Pro.
  20. Aviso: los pasos 20-54 provienen de una guía que está marcada como "En progreso".
    MacBook Pro 16" 2021 USB-C Ports Replacement, Unfasten the antenna bar's connector bracket: paso 20, imagen 1 de 2 MacBook Pro 16" 2021 USB-C Ports Replacement, Unfasten the antenna bar's connector bracket: paso 20, imagen 2 de 2
    • Use a T3 Torx screwdriver to remove the three 2.1 mm screws securing the antenna board bracket and coaxial cable cover to the frame.
  21. MacBook Pro 16" 2021 USB-C Ports Replacement: paso 21, imagen 1 de 2 MacBook Pro 16" 2021 USB-C Ports Replacement: paso 21, imagen 2 de 2
    Comprar
    • Use tweezers, or your fingers, to remove the cover on top of the antenna bar's coaxial cables.
  22. MacBook Pro 16" 2021 USB-C Ports Replacement, Disconnect the antenna bar: paso 22, imagen 1 de 2 MacBook Pro 16" 2021 USB-C Ports Replacement, Disconnect the antenna bar: paso 22, imagen 2 de 2
    • Use the tip of a spudger to pry up and disconnect the antenna bar's coaxial cable.
    • Repeat for the two other cables.
    • During reassembly, these can be tricky to reconnect. Hold each connector in place over its socket and press down with the flat end of a spudger. The connector should snap into place.
  23. MacBook Pro 16" 2021 USB-C Ports Replacement, Unfasten the display cable covers: paso 23, imagen 1 de 2 MacBook Pro 16" 2021 USB-C Ports Replacement, Unfasten the display cable covers: paso 23, imagen 2 de 2
    • Use a T3 Torx driver to remove the four 2.1 mm screws securing the display cable covers.
  24. MacBook Pro 16" 2021 USB-C Ports Replacement, Remove the display cable covers: paso 24, imagen 1 de 2 MacBook Pro 16" 2021 USB-C Ports Replacement, Remove the display cable covers: paso 24, imagen 2 de 2
    • Use tweezers, or your fingers, to remove the two display cable covers from the logic board.
  25. MacBook Pro 16" 2021 USB-C Ports Replacement, Disconnect the display cables: paso 25, imagen 1 de 3 MacBook Pro 16" 2021 USB-C Ports Replacement, Disconnect the display cables: paso 25, imagen 2 de 3 MacBook Pro 16" 2021 USB-C Ports Replacement, Disconnect the display cables: paso 25, imagen 3 de 3
    • Use the flat end of a spudger to pry up and disconnect the two right-most display cable press connectors secured to the logic board.
  26. MacBook Pro 16" 2021 USB-C Ports Replacement: paso 26, imagen 1 de 2 MacBook Pro 16" 2021 USB-C Ports Replacement: paso 26, imagen 2 de 2
    • Repeat the previous disconnection process for the remaining press connector.
  27. MacBook Pro 16" 2021 USB-C Ports Replacement: paso 27, imagen 1 de 2 MacBook Pro 16" 2021 USB-C Ports Replacement: paso 27, imagen 2 de 2
    • Peel back any tape covering the microphone cable connector.
  28. MacBook Pro 16" 2021 USB-C Ports Replacement: paso 28, imagen 1 de 2 MacBook Pro 16" 2021 USB-C Ports Replacement: paso 28, imagen 2 de 2
    • Use a spudger to gently pry up the locking flap on the ZIF connector for the microphone cable.
  29. MacBook Pro 16" 2021 USB-C Ports Replacement: paso 29, imagen 1 de 2 MacBook Pro 16" 2021 USB-C Ports Replacement: paso 29, imagen 2 de 2
    • Disconnect the microphone cable by sliding it out from its socket on the logic board.
  30. MacBook Pro 16" 2021 USB-C Ports Replacement, Unfasten the right-side cable covers: paso 30, imagen 1 de 2 MacBook Pro 16" 2021 USB-C Ports Replacement, Unfasten the right-side cable covers: paso 30, imagen 2 de 2
    • Use a T3 Torx driver to remove the 11 screws securing the right cable covers to the frame:
    • Nine 2.1 mm screws
    • One 2 mm screw
    • One 3.5 mm screw
  31. MacBook Pro 16" 2021 USB-C Ports Replacement, Remove the right cable covers: paso 31, imagen 1 de 2 MacBook Pro 16" 2021 USB-C Ports Replacement, Remove the right cable covers: paso 31, imagen 2 de 2
    • Use tweezers, or your fingers, to remove the five right cable covers.
  32. MacBook Pro 16" 2021 USB-C Ports Replacement, Disconnect the right speaker: paso 32, imagen 1 de 2 MacBook Pro 16" 2021 USB-C Ports Replacement, Disconnect the right speaker: paso 32, imagen 2 de 2
    • Use the flat end of a spudger to pry up and disconnect the right speaker's press connector.
  33. MacBook Pro 16" 2021 USB-C Ports Replacement, Disconnect the headphone jack: paso 33, imagen 1 de 2 MacBook Pro 16" 2021 USB-C Ports Replacement, Disconnect the headphone jack: paso 33, imagen 2 de 2
    • Use a spudger to pry up and disconnect the headphone jack's press connector.
  34. MacBook Pro 16" 2021 USB-C Ports Replacement, Disconnect the right USB-C ports: paso 34, imagen 1 de 3 MacBook Pro 16" 2021 USB-C Ports Replacement, Disconnect the right USB-C ports: paso 34, imagen 2 de 3 MacBook Pro 16" 2021 USB-C Ports Replacement, Disconnect the right USB-C ports: paso 34, imagen 3 de 3
    • Use a spudger to pry up and disconnect the right USB-C ports' two press connectors.
  35. MacBook Pro 16" 2021 USB-C Ports Replacement, Disconnect the MagSafe port: paso 35, imagen 1 de 2 MacBook Pro 16" 2021 USB-C Ports Replacement, Disconnect the MagSafe port: paso 35, imagen 2 de 2
    • Use a spudger to pry up and disconnect the MagSafe port's press connector.
  36. MacBook Pro 16" 2021 USB-C Ports Replacement, Disconnect the lid angle sensor cable: paso 36, imagen 1 de 2 MacBook Pro 16" 2021 USB-C Ports Replacement, Disconnect the lid angle sensor cable: paso 36, imagen 2 de 2
    • Use a spudger to pry up and disconnect the lid angle sensor's press connector.
  37. MacBook Pro 16" 2021 USB-C Ports Replacement, Unfasten the left cable covers: paso 37, imagen 1 de 2 MacBook Pro 16" 2021 USB-C Ports Replacement, Unfasten the left cable covers: paso 37, imagen 2 de 2
    • Use a T3 Torx driver to remove the six screws securing the left cable covers to the frame:
    • Four 2.1 mm screws
    • One 2 mm screw
    • One 3.6 mm screw
  38. MacBook Pro 16" 2021 USB-C Ports Replacement, Remove the left cable covers: paso 38, imagen 1 de 1
    • Use tweezers, or your fingers, to remove the three left cable covers.
  39. MacBook Pro 16" 2021 USB-C Ports Replacement, Disconnect the left speaker: paso 39, imagen 1 de 2 MacBook Pro 16" 2021 USB-C Ports Replacement, Disconnect the left speaker: paso 39, imagen 2 de 2
    • Use the flat end of a spudger to pry up and disconnect the left speaker's press connector.
  40. MacBook Pro 16" 2021 USB-C Ports Replacement, Disconnect the left USB-C port: paso 40, imagen 1 de 2 MacBook Pro 16" 2021 USB-C Ports Replacement, Disconnect the left USB-C port: paso 40, imagen 2 de 2
    • Use a spudger to pry up and disconnect the left USB-C port's press connector.
  41. MacBook Pro 16" 2021 USB-C Ports Replacement, Disconnect the Touch ID sensor: paso 41, imagen 1 de 2 MacBook Pro 16" 2021 USB-C Ports Replacement, Disconnect the Touch ID sensor: paso 41, imagen 2 de 2
    • Use a spudger to pry up and disconnect the Touch ID sensor's press connector.
  42. MacBook Pro 16" 2021 USB-C Ports Replacement, Disconnect the keyboard: paso 42, imagen 1 de 3 MacBook Pro 16" 2021 USB-C Ports Replacement, Disconnect the keyboard: paso 42, imagen 2 de 3 MacBook Pro 16" 2021 USB-C Ports Replacement, Disconnect the keyboard: paso 42, imagen 3 de 3
  43. MacBook Pro 16" 2021 USB-C Ports Replacement: paso 43, imagen 1 de 3 MacBook Pro 16" 2021 USB-C Ports Replacement: paso 43, imagen 2 de 3 MacBook Pro 16" 2021 USB-C Ports Replacement: paso 43, imagen 3 de 3
    • Use a spudger to gently pry up the locking flap on the two ZIF connectors for the keyboard cables.
  44. MacBook Pro 16" 2021 USB-C Ports Replacement: paso 44, imagen 1 de 3 MacBook Pro 16" 2021 USB-C Ports Replacement: paso 44, imagen 2 de 3 MacBook Pro 16" 2021 USB-C Ports Replacement: paso 44, imagen 3 de 3
    • Disconnect the keyboard and keyboard backlight cables by sliding them out from their sockets on the logic board.
  45. MacBook Pro 16" 2021 USB-C Ports Replacement, Disconnect the fans: paso 45, imagen 1 de 3 MacBook Pro 16" 2021 USB-C Ports Replacement, Disconnect the fans: paso 45, imagen 2 de 3 MacBook Pro 16" 2021 USB-C Ports Replacement, Disconnect the fans: paso 45, imagen 3 de 3
    • Peel back any tape covering the right fan cable connector.
  46. MacBook Pro 16" 2021 USB-C Ports Replacement: paso 46, imagen 1 de 2 MacBook Pro 16" 2021 USB-C Ports Replacement: paso 46, imagen 2 de 2
    • Use a spudger to gently pry up the locking flap on the ZIF connector for the right fan cable.
  47. MacBook Pro 16" 2021 USB-C Ports Replacement: paso 47, imagen 1 de 2 MacBook Pro 16" 2021 USB-C Ports Replacement: paso 47, imagen 2 de 2
    • Disconnect the right fan cable by sliding it out from its socket on the logic board.
  48. MacBook Pro 16" 2021 USB-C Ports Replacement, Reposition the right fan cable: paso 48, imagen 1 de 2 MacBook Pro 16" 2021 USB-C Ports Replacement, Reposition the right fan cable: paso 48, imagen 2 de 2
    • The right fan cable is lightly adhered to the logic board.
    • Pull the fan cable away from the logic board with tweezers to separate the adhesive.
    • The fan cables are incredibly delicate and prone to tearing; use caution when bending them with tools.
  49. MacBook Pro 16" 2021 USB-C Ports Replacement: paso 49, imagen 1 de 2 MacBook Pro 16" 2021 USB-C Ports Replacement: paso 49, imagen 2 de 2
    • Repeat the previous disconnection and reposition procedure for the left fan cable.
  50. MacBook Pro 16" 2021 USB-C Ports Replacement, Unfasten the logic board: paso 50, imagen 1 de 2 MacBook Pro 16" 2021 USB-C Ports Replacement, Unfasten the logic board: paso 50, imagen 2 de 2
    • Use a T5 Torx driver to remove the ten screws securing the logic board to the frame:
    • Six 3.8 mm screws
    • Four 4.6 mm screws
    • Use a 4 mm Hex driver to remove the two 6 mm screws securing the logic board to the frame.
    • Use a T6 Torx driver to remove the two 6 mm screws securing the heat sink to the logic board and frame.
  51. MacBook Pro 16" 2021 USB-C Ports Replacement, Release the logic board's clips: paso 51, imagen 1 de 2 MacBook Pro 16" 2021 USB-C Ports Replacement, Release the logic board's clips: paso 51, imagen 2 de 2
    • Insert a spudger between the right side of the logic board and the frame.
    • Pry up with the spudger to release the logic board from its clips.
  52. MacBook Pro 16" 2021 USB-C Ports Replacement: paso 52, imagen 1 de 2 MacBook Pro 16" 2021 USB-C Ports Replacement: paso 52, imagen 2 de 2
    • Insert a spudger between the bottom of the logic board and the frame.
  53. MacBook Pro 16" 2021 USB-C Ports Replacement, Remove the logic board: paso 53, imagen 1 de 3 MacBook Pro 16" 2021 USB-C Ports Replacement, Remove the logic board: paso 53, imagen 2 de 3 MacBook Pro 16" 2021 USB-C Ports Replacement, Remove the logic board: paso 53, imagen 3 de 3
    • Gently lift up the logic board by its right side to completely release the clips.
    • If it feels like it's not coming out, check that all the cables are disconnected.
    • Pull the logic board away from the left side of the device to separate the HDMI and SDXC ports from their slots in the frame.
    • Remove the logic board.
  54. MacBook Pro 16" 2021 USB-C Ports Replacement, Reassembly information: paso 54, imagen 1 de 3 MacBook Pro 16" 2021 USB-C Ports Replacement, Reassembly information: paso 54, imagen 2 de 3 MacBook Pro 16" 2021 USB-C Ports Replacement, Reassembly information: paso 54, imagen 3 de 3
    • When reinstalling the logic board, insert the left side first to reposition the HMDI and SDXC ports.
    • Use your fingers to slightly compress the HDMI port to fit it into its recess. Otherwise, the logic board won't sit correctly.
    • Make sure all of the connectors are above the logic board before securing it back into the frame.
    • If you're having trouble positioning the connectors, use tape to keep them out of the way.
  55. MacBook Pro 16" 2021 USB-C Ports Replacement, USB-C port legend: paso 55, imagen 1 de 2 MacBook Pro 16" 2021 USB-C Ports Replacement, USB-C port legend: paso 55, imagen 2 de 2
  56. MacBook Pro 16" 2021 USB-C Ports Replacement, Unfasten the left USB-C port: paso 56, imagen 1 de 2 MacBook Pro 16" 2021 USB-C Ports Replacement, Unfasten the left USB-C port: paso 56, imagen 2 de 2
    • Use a T5 Torx driver to remove the two 3.7 mm screws securing the left USB-C port.
  57. MacBook Pro 16" 2021 USB-C Ports Replacement, Remove the USB-C port: paso 57, imagen 1 de 2 MacBook Pro 16" 2021 USB-C Ports Replacement, Remove the USB-C port: paso 57, imagen 2 de 2
    • Use your fingers to remove the USB-C port.
  58. MacBook Pro 16" 2021 USB-C Ports Replacement, Unfasten the USB-C ports: paso 58, imagen 1 de 2 MacBook Pro 16" 2021 USB-C Ports Replacement, Unfasten the USB-C ports: paso 58, imagen 2 de 2
    • Use a T5 Torx driver to remove the four 3.7 mm screws securing the right USB-C ports:
    • Top port
    • Bottom port
    • If you're replacing a single port, only remove the screws for the corresponding port.
  59. MacBook Pro 16" 2021 USB-C Ports Replacement, Remove the USB-C ports: paso 59, imagen 1 de 3 MacBook Pro 16" 2021 USB-C Ports Replacement, Remove the USB-C ports: paso 59, imagen 2 de 3 MacBook Pro 16" 2021 USB-C Ports Replacement, Remove the USB-C ports: paso 59, imagen 3 de 3
    • Use your fingers to remove the USB-C ports.
Conclusión
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our MacBook Pro 16" 2021 Answers community for help.
Una persona más ha completado esta guía.
Alex Diaz-Kokaisl
Miembro Desde 01/16/22
129,318 Reputación
600 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
140 Miembros
18,077 Guías creadas
2 comentarios
Great article but misses a critical piece: where, exactly, do you purchase replacement USB C ports? Without that information, this article is almost useless.
Rick Goulian - Contestar
There is a link to buy the USB-C board under “Parts” at the top of the article.
Graham Baran-Mickle -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 16
Ultimos 7 días: 88
Ultimos 30 días: 302
Todo El Tiempo: 10,759
