Introducción
Follow this guide to replace the back button boards in your Sony DualSense Edge controller.
If your LB or RB button isn't working correctly, you may need to replace the back button board.
Qué necesitas
Place the controller on a work surface with the joysticks facing down.
Use a spudger or your finger to slide the Release tab to the left. The front trim should fall to the table.
Lift the controller up, leaving the front trim on the table.
Flip the controller over so the joysticks are facing up.
Lift the metal lever that holds the joystick in place until the joystick slides out slightly.
Slide the joystick out from its slot.
Insert the flat edge of an opening pick between the black portion of the rear trim and the top cover, near the joystick lever.
Slide the opening pick towards the bottom of the grip to release the clips.
Slide the pick around to the rear of the controller and flip the controller over so the buttons are facing down.
Slide the opening pick around the edge of the rear trim to release the clips.
Slide the opening along the edge of the trim on the other grip.
Once all clips are released, remove the trim.
Insert the flat end of a spudger in the gap between the L1 and L2 buttons.
Use the spudger to pry out the L1 button.
Repeat this process to remove the R1 button.
Rotate the controller so the grips are pointing towards you.
Use a pair of angled tweezers to lift the right end of the release bar spring off of the white post.
Use a pair of tweezers or your fingers to slide the release bar to the left.
Slide the release bar away from the controller to remove it.
Remove the nine screws securing the rear case:
Seven 6.4 mm‑long screws
Two 10.5 mm‑long screws
Insert the point an opening pick in the gap along the outside edge of one of the controller grips, near the bottom.
Pry with the opening pick to separate the rear case from the front case by releasing the clips that hold them together.
Continue prying along the edge of the controller until one side is separated.
Hold the main body of the controller with one hand.
Lift the rear case with your other hand. It should lift at an angle.
Pushing slightly towards the L and R buttons, lift the rear case off of the controller and remove it.
Use a pair of tweezers or your fingers to lift the cover from the controller.
Slide the flat end of the cover under the plastic tab in the rear case.
Lift the battery and move it to the right, so the connector underneath the battery is accessible.
Use the flat end of a spudger to pry up the low profile connector.
Remove the battery.
While holding the back button switch down, remove the two 6.4 mm‑long screws securing the back button bracket.
Use a pair of tweezers or your fingers to lift and remove the back button switch, being careful not to lose the plastic covers on the sides of the switch.
Use a pair of tweezers to disconnect the vibration motor cable from the back button board by lifting the JST connector out of its socket.
Use a pair of tweezers to move the back button ribbon cable out from its plastic clip.
Use a pair of tweezers to disconnect the back button board ribbon cable by gripping the blue tab and pulling away from the back button board.
Insert a pair of angled tweezers under the bottom inside corner of the back button board.
Use the tweezers to pry up the back button board until it comes free of the adhesive underneath it.
5 comentarios
yeah where are these PCB boards?
I cant find them either… where to buy
I also need this board. The little button stopped popping back up.
In my device the plastic parts under the metal carrier broke. It has a sort of lever action that I'm pretty sure was intended to break.
It would be no good to reassemble it with baking soda and super glue. Aside from buying a scrap controller there doesn't appear to be a way to return it to original.
Any help appreciated.
