Saltar al contenido principal
flag|student_wiki]
Galaxy will not turn on
No matter what you do Galaxy won't turn on or is continuously restarting.
Dead/drained battery
If your Galaxy won't turn on you may simply have a drained or dead battery, especially if the device hasn't been used in a while. Try plugging your galaxy into a computer or AC adapter and wait to see if device starts to charge. If device does not respond to either charging source you may need a battery replacement.
Faulty Motherboard
If your Galaxy does not respond to being plugged into a power source, the most plausible problem might be the motherboard. For instruction on how to replace motherboard view this page
Galaxy has cosmetic damages
The screen or the frame of the device has a crack but the phone is fully functional.
Cracked or broken screen
If your Galaxy has a cracked or broken screen then you may simply need to replace your screen even if the device is fully operational.
Cracked or broken mid-frame
If your Galaxy has a cracked or broken mid - frame then your phone may be more vulnerable to breaking. To replace broken mid-frame refer to replacement guide.
Blank/unresponsive screen
The screen appears blank or frozen but the device is fully powered.
Restart Galaxy
Sometimes you have to restart the Galaxy for it to respond again. To restart your Galaxy when it is unresponsive, press and hold the sleep/wake button located on the right side of the device until the Samsung logo appears ( ~5 seconds).
Display Assembly
It is possible that the display is bad if nothing seems to appear to be damaged. If Galaxy starts normally multiple times and the blank screen still occurs then the display might need to be replaced.
Motherboard
If your Galaxy does not respond to being plugged into a power source, the most plausible problem might be the motherboard. For instruction on how to replace motherboard view this page.
Audio distortion
When you plug in headphone or speakers the audio doesn't play properly.
Bad audio jack
It is most likely that the cause of audio distortion is a bad audio jack once you have realized that there no problem with the external speakers. For replacement of audio jack see the audio replacement page.
Bad earpiece speakers
It is unlikely that your phone's earpiece speaker is bad, but if found to be source of the problem you need to replace it with a new speaker.
Galaxy will not charge
The battery will not charge when Galaxy is plugged in.
Faulty charging port
If your Galaxy does not respond to being plugged into a power source, the problem may lie in a broken charging port. To replace charging port view the port page.
Dead battery
If your Galaxy still won't charge you may simply have a dead battery.If device does not respond to charging source you may need a battery replacement, especially if there is no problem with the charging port.
No wireless connection
Having trouble connecting to the internet?
Wireless connection is set off
If your galaxy won't connect to wi-fi on it's own verify that it's wireless connection settings are enabled.
Faulty Antenna
If you are still having problems connecting to wi-fi and the issue is not with the wireless settings then you may have a faulty antenna. If your antenna is faulty then you may need to get it replaced.
Un agradecimiento especial a estos traductores:
en es
100%
¡ hernando nos está ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
54 comentarios
My galaxy keeps showing a message that its device memory is full so I cannot receive any messages. I deleted a whole lot of stuff but still the same message. I would like to save what I have not deleted so far and clear the phone completely but can't even do that cause when I tried transferring my pics and videos to my laptop, it is showing that the folder is empty. Anyone has any ideas?
blossomingpeach - Contestar Compartir
Clean your cache from your settings menu, and buy a sd card to transfer your apps and pics, I have a 32 gb sd card and have no issues with it now, but your phone has to have a certain amount of free ram to operate properly.
sammydoll2300 - Contestar Compartir
What happened when the cell overheat and turn off completely by itself
Carla - Contestar Compartir
Can't get galaxy grand prime to connect to my Google account says unfortunately Google has stopped. So therefore can't download apps
Christina Bramblett - Contestar Compartir
My phone runs slow
Tammy - Contestar Compartir
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 34
Ultimos 30 días: 72
Todo El Tiempo: 43,908
