Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
El Stylo 6 es un teléfono inteligente Android de gama media con lápiz óptico lanzado por LG en 2020. Se identifica por el número de modelo Q730, seguido de caracteres específicos del operador o de la versión.
Fingerprint Sensor not working
Hi, very recently i tried fixing my phone (Lg Stylo 6) myself after watching a teardown video and by following steps from a previous Ifixit guide but now I have this one issue after reassembling, my fingerprint sensor stopped working. As a beginner I'm not sure if the back was supposed to be attached to something after reattaching the back cover. Before proceeding earlier it wasnt attached to anything unlike the other connectors to the motherboard so what did i do wrong? Nothing was damaged I did everything I could and when I tried to test the hardware in settings for the first time it said "Could not test hardware" Please help me its a bit embarrassing I messed up on my first time
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
3 comentarios:
I am curious; exactly what did you fix on your phone?
- de
Well the buttons on my Stylo 6 started to fall out, so months ago I had to tape over them just to keep them in place though I did lose the volume button, after I acknowledged they were loose. So I decided to buy replacements on Aliexpress, when they arrived I wanted to enter the phone and secure the new ones firmly, despite never trying that before, I was nervous, for I didn't want to mess up my phone but I still tried anyway, now when I was in and it was time to replace them, what I realized is I accidentally bought the wrong buttons (it was meant for another LG Stylo 6 model) so after realizing my mistake I reassembled everything back with assistance from my father. Everything was functioning well but, eventually I realized the fingerprint sensor was responding, I tried settings again to test and see if the hardware is ok but it told me the fingerprint sensor isn't working so that's what led me to here to see why that's the case. After seeing your response I believe that could be the reason
- de
When attaching the back cover, I'll admit I may have done it hastily it took me a while to realize everything maybe working but the fingerprint sensor might've need more attention than just simply reattaching the cover. When I saw those YouTube videos they just placed it back so I did the same as well thinking everything would be fine, but in retrospect, I was wrong.
- de
Agregar un comentario
1 Respuesta
Hey, no shame here; there's a learning curve to fixing phones and nobody's going to blame you if you didn't get it 100% right your first time out.
Anyway, your phone doesn't have a ribbon cable from the fingerprint sensor plugged into the motherboard. What they did instead is put in a set of spring contacts so that when the back is installed, those contacts press against pads on a ribbon cable leading to the sensor. This picture shows you what I mean.
Imagen
The red box shows the location of the spring contacts on the motherboard, and the green box is the corresponding pads on the phone's back. Use a pencil eraser to clean the pads and carefully go over the spring contacts to make sure there's no oxidation or dirt keeping the pins from making contact. Of course you'll also want to examine those springs carefully looking for any that are bent or broken; that would explain the issue. If you find any that are bent out of place, you may be able to carefully straighten them out with some fine tip tweezers.
The image was taken from a YouTube video showing the replacement of the fingerprint sensor by purchasing a new back that comes with the sensor and just replacing the whole back.
How to fix Finger Print Sensor On Your Android Smartphone - Most Models - YouTube
If you'd like a second opinion, open your phone back up and take some high resolution closeup photos of both connectors and add them to your question; that way we can see what you see and might be able to offer opinions. This guide shows how to add images.
Adding images to an existing question - iFixit Repair Guide
Good luck, and be sure to come back and let us know what you find
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Antwone Bailey estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 41
Todo El Tiempo: 41
