Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
La soldadura es un método para conectar dos piezas de metal derritiendo otro metal de aporte entre ellas. Existen muchos tipos de soldadura, pero este artículo está diseñado para enseñarte los conceptos básicos de la soldadura eléctrica.
Attach camera to microscope
I am using an Amscope microscope for soldering. I would like to attach a Nikon Z mount camera to it. What solutions have worked for folks? Thank you!
Update (09/03/26)
The microscope is an Amscope SM-4T
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
You'll need a 30mm tube that fits into the microscope camera port with the needed mount. I got my microscope with the video camera with a C mount.. Contact Amscope for the needed tube or try Edmond Scientific
Fue útil esta respuesta?
Puntuación 0
3 comentarios:
Thank you Dan. I will have a look at Edmond. There is also a place called Microscope World that may have a solution. The ID of the port is 23mm with an OD of 25mm. You have headed me in the right direction and I will make some phone calls.
- de
@b53evans - Why are you using the eyepiece not the third camera port? I haven't seen the need to use the eyepiece when you have a binocular microscope. Doesn't this model offer it? The lookup I did implied it did.
- de
DanJ, you are correct. The measurements above are the camera port. I believe I have found a solution that will attach to the Z8 lens attachment ring and then drop into the camera port (https://www.microscopeworld.com/microsco...). I will order it and update this thread. Thanks for the push toward a solution.
- de
Añadir tu respuesta
b53evans estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 19
Todo El Tiempo: 52
