Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
El Range Rover Sport fue prefigurado por el prototipo Range Stormer, presentado en el Salón Internacional del Automóvil de Norteamérica de 2004.
Battery draining while idol
Hi we have a 2008 range rover sport. We have an issue with our battery being drained if left idol for a few days. Weve changed the battery and the alternator and still something is draining her battery while idol and parked outside the house. Has anyone else had this problem please and did you come across a solution thanks
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
1 Respuesta
Solución Elegida
Hi @sam48298
With the engine turned off, disconnect the -ve battery cable from the -ve battery post and connect an Ammeter (function of a DMM - digital multimeter) in series connection between the -ve battery cable and the -ve battery post i.e. -ve battery post → Ammeter → -ve battery cable and measure what the quiescent current value is.
Normally the quiescent current for most vehicles is in the range of 50mA-80mA. (mA = milliAmps)
If the current value is greater than this value, there is a parasitic current flowing that is draining the battery.
You need to remove the fuses from the fuse boxes, one at a time and check what the current is with a fuse removed. If there's no change, replace the fuse (so that you don't mix up which fuse goes where) and remove the next one and so on until when you remove a fuse the current value drops to the normal quiescent current value.
This is best done by two people, one removing/replacing the fuses, whilst the other watches the Ammeter. Perhaps also start with the passenger compartment fuse box as this has the lower rated fuses that are more specific to features and circuits, rather than the engine bay fuse box which mostly has the higher rated fuses which then feed the lower rated fuses
Once you've found the fuse which when removed causes the current to drop back to normal, check the fuse information in the fuse box lid or the owner manual to find out what the fuse is used for. Once you know that , you're halfway to finding out what is causing the problem
Fue útil esta respuesta?
Puntuación 1
1 comentario:
Thank you for that i will try that
- de
Añadir tu respuesta
Sam estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 21
Todo El Tiempo: 128
