Remove alternator from engine
I have alternator broke but can't find space to pull the alternator out
Es esta una buena pregunta?
@donaldmart53225 here are the instructions for the Generator Removal from the workshop manual. If there is anything in the way etc. you want to go ahead and post some good pictures of your situation. That way we can see what you see and hopefully find a solution. Agregar imágenes a una pregunta existente
@donaldmart53225 all the wires are loose and your removed all the bolts etc.? Where are you stuck? You normally are supposed to drop the engine. Take a look on here to see how to try and do it without dropping the engine, or on here where you drop the engine.What a PITA
Fue útil esta respuesta?
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 25
Todo El Tiempo: 164
1 comentario
Alternator is loose but I can't get out frustrating
- de Donald Martin
