Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
La Makita 9554NB es una amoladora angular eléctrica con cable diseñada para trabajos de desbaste y corte, que cuenta con un motor de 710 W, un diámetro máximo de disco de 4-1/2 pulgadas y una velocidad sin carga de 11,000 RPM. Este modelo presenta un diseño en negro y azul, con unas dimensiones de 10-5/8 x 5-1/8 x 4 pulgadas y un peso de 4.6 libras.
no function and overheating
my ginder is not functioning and overheating, how to fix this?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Respuesta Más Útil
@hammedtalus1335 not quite sure how this "not functioning and overheating" works, since if it is not functioning it should not be overheating. Now, it is possible that your grinders motor is still pulling amps but not rotating because of a seized bearing. You will have to take your grinder apart and have a look at the bearings. It is fairly common that the bearings either wear out or get gummed up by debris with heavy use of the grinder.
To work on your grinder use something like this video Once you have it apart post some well focused images of what you find out, with your question. That way we can see what you see and hopefully help you out further. Agregar imágenes a una pregunta existente
While you work on your grinder, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
Hammed Talusan Abdula estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 23
Todo El Tiempo: 157
