Saltar al contenido principal
Envío gratis en pedidos nacionales de $75 o más
El portátil HP Probook 4330s viene con un procesador Intel Core i7/i5/i3 de 2ª generación o un Intel Celeron B810. El HP Probook 4330s está equipado con una pantalla HD de 13.3”, Mobile Intel® HM65 Express, Bluetooth 3.0, Wi-fi, cuatro puertos USB 2.0, un puerto VGA, un puerto HDMI y una webcam HD.
How to fix boot error problem
Video to solve this problem
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
1 comentario
Hi @aashishnana67
You have asked the same question 3 times now and had responses to the first 2 questions asking for more information so relevant answers could be provided.
1st question
2nd question
You have not responded to their requests for more information.
Please stop asking the same question and respond with more information as to what the exact problem is.
Moderator.
- de Compartir
Agregar un comentario
1 Respuesta
Respuesta Más Útil
A boot error on an HP ProBook 4530s usually comes from incorrect BIOS settings, a failing drive, or corrupted boot files. First, enter BIOS (press F10 on startup) and ensure the hard drive is detected and set as the first boot device. If detected, run HP Diagnostics (F2) to check HDD health. If the drive fails tests, replace it. If the drive passes, boot from a Windows installation USB, choose Repair your PC, then run Startup Repair. You can also use Command Prompt to run bootrec /fixmbr, /fixboot, and /rebuildbcd. Update BIOS if needed. If errors persist, reinstall Windows.
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
Aashishnana 67 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 32
Todo El Tiempo: 181
