Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
How to replace the keyboard
Now I will show you how to replace the keyboard of a Dell Inspiron laptop.
You have to prepare some equipment including a flathead screwdriver and a new keyboard.
Remember to remove all the peripherals like the AC adapter and battery from the laptop. Don't use a razor blade because it might leave some scratches on your laptop.
There are 8 steps in total:
  • First, slide two battery-release latches into the unlocked position.
  • Next, remove the battery from the battery base.
  • Then, turn over the laptop and open it.
  • After that, use a small flathead screwdriver to pry away 5 keyboard latches.
  • Next, you should carefully lift the keyboard.
  • Then, disconnect the keyboard cable.
  • After that, remove the old keyboard.
  • Finally, reverse the above steps to install the new keyboard.
I have just told you the steps to change the keyboard. If you have any questions, don't hesitate to contact us.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
1 comentario
I need some images and instructions on each image
- de
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Hi @jaygizo
Here's the ifixit Desmontaje del AST Ascentia 520i guide that may help.
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
Anh Tuan estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 16
Todo El Tiempo: 158
