Saltar al contenido principal
Envío gratis en pedidos nacionales de $75+
¿Qué hay dentro de un chip? ¿Cómo funciona? Los chips informáticos también se llaman circuitos integrados, circuitos integrados monolíticos, CI, chips o microchips.
Help Identifying a chip
Hello, I have a Vizio S2920w Soundbar which has a blown chip on it. I was wondering if anyone here could help identify it. Its marked 9F 2 and has U7 written on the board beside it. All help would be appreciated!
Imagen
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
3 comentarios:
Hi, I’m having the same problem. Were you able to identify the component? That would be a great help.
- de
@albert45304 from whatever is left to identify the component, this could very well be a Voltage regulator. Check on here You can relatively easy identify if it is a V Reg if one of the middle pins looks a bit odd. Again datasheet will show what I mean by that. You can also desolder the component and check the bottom side for what the center pins look like.
- de
@oldturkey03 Thanks, that was really helpful. It’s definitely one of these.
- de
Agregar un comentario
1 Respuesta
It looks like you have some other material to remove and underneath that there are the actual identifying markings.
Fue útil esta respuesta?
Puntuación 0
1 comentario:
Unfortunately I cannot remove that as thats the actual plastic itself which has burnt and turned white.
- de
Añadir tu respuesta
TechVid estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 18
Todo El Tiempo: 251
