Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Una fuente de alimentación ininterrumpida (UPS) es un dispositivo eléctrico que proporciona energía de respaldo a equipos críticos en caso de un corte de energía u otros problemas relacionados con la energía.
Check the correct functioning of the PCBA
Lately I can't see anything in the ViewPower program and when I contacted BlueWalker support they told me that the problem is the PCBA.
How can I check it to see if it really isn't working?
Imagen
Imagen
UPS Model: PowerWalker VI 1000 PSW Schuko
Update (09/08/24)
I have this:
Imagen
How do I add port to Firewall exclusions in Windows 11?
In order to start, the following screen must appear:
Imagen
How can I start it automatically?
I solved the problem.
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
Hi @piero90
If you haven't already done so, here's the S.O.P. How To Check ViewPower Status And Open Port guide that may help.
Fue útil esta respuesta?
Puntuación 2
10 comentarios:
Thanks for the guide
- de
@piero90
Did the problem only occur after you updated to Win11 (if you did) or not?
Here's a video that may help.
- de
I followed the video but nothing
- de
@piero90
if the port is "open" and there's no connection with the UPS then most likely it is the UPS unless it is in the wiring/cable etc between the UPS and the PC
- de
I must try to change the cable to verify if the problem is UPS
- de
Mostrar 5 comentarios más
Añadir tu respuesta
Piero Sabino estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 3
Ultimos 30 días: 16
Todo El Tiempo: 347
