Code c4 on washer
What if your wash read c4 and your house water pressure is high
Es esta una buena pregunta?
The 4E (4C) error code indicates that the washing machine has detected a problem with the water supply. The most common reason for this error is a blocked or kinked water supply hose. Try the below troubleshooting steps to resolve.
Check the water hose
A problem with the water supply is usually the result of low water pressure or a low flow rate on the mains water supply to the machine. This means that the water feeding into the machine is not flowing with enough force. The water pressure must be between 0.5bar and 8bar.
Fully power off and unplug your washing machine at the mains.
Move the machine forward to give access to the water hoses.
Check that there are no kinks or bends in the water hose connected to the machine and make sure the hose is not damaged..
2
Check the water supply
Check that the water tap connected to the washing machine is open to full.
3
Clean the water hose mesh filter
at least twice a year to prevent build up.
Turn off the water supply
Disconnect the inlet hose from the water supply
Disconnect the L-shaped arm from the washing machine
Gently pull out the mesh filters
Rinse the mesh filters under running water until they’re clean
Reinsert the mesh filters
Connect the hose again, first to the washing machine and then to the water supply
Make sure the connections are watertight
Turn on the water supply
4
Clean the dispenser drawer
Occasionally, a 4C check code error message may be displayed if there is a blockage in the dispenser drawer.
Remove the drawer
Check for any obstructions
Clean if required
Insert the drawer back into the washing machine
Fue útil esta respuesta?
Ultimas 24 horas: 3
Ultimos 7 días: 7
Ultimos 30 días: 24
Todo El Tiempo: 1,472
