The Disc could not be read.
Red Error Message: The Disc could not be read. Please read the Nintendo Gamecube instruction book for more information.
Es esta una buena pregunta?
@johnllovesr try and see if it reads an audio disk as well as different game disk then the one you were trying. Sometimes a disk can cause this error.
It is possible that this is either a dirty laser or a failing laser. First try one of those commercially available CD cleaner kits. Run that a couple of times. If that does not work you could could try to increase the power to your laser. Follow this guide. Just be moderate, you do not want to burn it out. The other thing to try would be a recalibration of the lens. For that follow this guide. After that I'd suggest that you replace either the lens or the optical drive. Sustitución de la Lente del Láser Óptico de la Nintendo GameCube Sustitución del Conjunto de Unidad Óptica de la Nintendo GameCube
Guía
Dificultad:
Moderado
30 - 45 minutes
Guía
Dificultad:
Moderado
30 minutes
Guía
Dificultad:
Moderado
30 minutes
Guía
Dificultad:
Moderado
20 - 25 minutes
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 14
Todo El Tiempo: 49
