Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Mobile not vibrating software problem
Vibrate motor is ok bit. Mobile not
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
1 comentario:
@harmansand19435 so the only problem is that the vibrate does not work? Everything else does? How did you check the vibrate motor?
- de
Agregar un comentario
1 Respuesta
Hi @harmansand19435
Here's an image the vibrate motor trouble shooting flowchart from the service manual that may help.
There's also an image, one zoomed in and one normal size of the board layout showing where the components mentioned in the flowchart are located.
It the troubleshooting tests prove that the hardware is OK, then you may have to reset the phone back to default using a factory restore to see if it is a software problem. Note: Be aware that doing this will erase all your personal data and downloaded apps, so backup the phone to the cloud or a computer before you do the restore.
Imagen
Imagen
(click on image)
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Harman Sandhu estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 13
Todo El Tiempo: 247
