Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Un disco duro SATA de 250 GB y 3,5" lanzado por Western Digital.
Hdd is not getting detected
When i turn on the pc harddisk turns on and then turns off after 10-15 seconds. I want to recover my data from that disk. I tried to contact manufacturers of that disk but they say that disk is a copy and not a genuine one. I also tried to connect that drive to other pc but there also not getting detected
What should i do ?
That data is very much important to me. Please help
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 6
1 comentario
I have already recovered some HD's by removing the electronic board and resoldering it with the hot air rework station.
- de
Agregar un comentario
2 Respuestas
Respuesta Más Útil
@khushaldhumane explain to us what this means "they say that disk is a copy". There are two possible failures, The controller board or the mechanical part. If it is mechanical, you want to leave your hands off and send your drive for data recovery to a place that specialize in this. Those are not cheap.
For the controller issue, you could try to replace the controller board. I've done that a few times and successfully removed data from those drives. But, you will need to get the right board etc. Not always an easy find. Check this guide for what I am referring too,
Reemplazo del controlador de disco duro Hitachi GST Deskstar HDS721010CLA332
If you need more info or guidance, post some good pictures of your board etc. with your Question. that way we can see what you see.
Agregar imágenes a una pregunta existente
Imagen de iFixit
Guía
Dificultad:
Muy fácil
2 - 5 minutes
Imagen de Hitachi GST Deskstar HDS721010CLA332 Hard Drive Controlador
Guía
Dificultad:
Moderado
20 minutes
Fue útil esta respuesta?
Puntuación 2
I am also stuck in the almost same situation. In this case, put your HDD in the sun for around 1 hour, then let it cool down for 10 minutes, and then insert it. In some cases, the HDD is fully recovered, and in some cases, it shows up in your PC for around 5-6 hours or a day. I recovered my data with this method.
Puntuación 0
Añadir tu respuesta
Khushal Dhumane estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 7
Ultimos 7 días: 39
Ultimos 30 días: 158
Todo El Tiempo: 3,078
