Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
El proyector Vankyo V7000 (YG551) ofrece una resolución Full HD de 1080p con 3800 lúmenes de brillo. Fue lanzado en 2020.
How to open device?
How do I open the device? My cats knocked the projector off it's place holder and the focus doesn't work as it should. it seems like the lens was knocked out of its focus track and no longer spins unless I hold it for a long time. But it never gets the focus right. If I could get the body open, I could pop it back into place but I don't know where to start.
Thank you!
Es esta una buena pregunta?
Puntuación 2
3 comentarios
@jayeff
Looks like they redesigned as I don't have those screws at the bottom nor the pieces he pulls out in the beginning of the video :(
- de
How did you finally open it?? I have a similar issue with the lens, did you discovered what happen??
- de
I have my grandson's YG551 that his mother wanted to use as a classroom device but it wasn't working. These things are NOT made to be opened. There are some very deep screws that need a long very thin Phillips (I think) screws) which are virtually unreachable (and I have a LOT of different screwdrivers). Plastic push together pieces break when pulled apart. It doesn't take up a lot of room in the trash can.
- de
Agregar un comentario
1 Respuesta
Solución Elegida
Hi @kennediehurt
Here's a video that may give you some clues as to how to open your projector.
I realize that is it not the same model, but mostly manufacturers don't alter things that much between models or if they do not often.
Worth a look perhaps anyway.
Fue útil esta respuesta?
Puntuación 3
2 comentarios:
@jayeff
- de
@kennediehurt
If the unit has rubber "feet" try removing them as sometimes there are screws underneath. Also check under any labels as they could also have recessed screws there.
Please unaccept my answer as it didn't fix your problem.
Cheers
- de
Añadir tu respuesta
Kennedie Hurt estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 46
Todo El Tiempo: 920
