Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Una lavadora de carga superior de Fisher&Paykel.
Not completing spin cycle
machine seems unbalanced no matter how often I re arrange the contents. It stops on rinse and beeps, and won’t move forward- progress- with the cycle. Happens more often than not recently.
Unsure why is now unbalanced. Machine is one of the earlier ones (low agitator)
Update (12/19/2022)
F&p Aquasmart WL70T60D 92127-A-NZ
Aso during the rinse and spin it thumps and bashes around really badly before stopping and beeping and the rinse light stays on, or if I progress it to spin does the same until it stops with the spin light on - and the clothes are still wet.
Been doing it for the past 4 washes perhaps.
I have done two auto tub cleans
I have replaced the straps that attach in the four corners but hasn't helped
Es esta una buena pregunta?
Puntuación 2
Agregar un comentario
2 Respuestas
Solución Elegida
Hi,
Not sure re the model but check if the suspension rods are still attached OK. These are what the straps that you replaced are connected to.
I couldn't find a service manual for your model but I think that this service manual for a comparable USA model might be very close. Run the diagnostics as shown on p.38 to see what error codes if any are shown.
Also here's the parts list for the AU model which may help if you need parts. Search online using the part number to find suppliers.
Fue útil esta respuesta?
Puntuación 1
1 comentario:
Suspension rods worn out
The straps dont do much
- de
Fixed previously - found some used but not too used suspension rods and that worked.
Had already bought and installed new straps.
I had much fun? using jeffs pdf manual and stripping down then cleaning the everything - including waterblasting the bowl and cleaning out the flapper.
All 100% now
Puntuación 1
1 comentario:
The suspension rods are springs in this model, no oil like others. If you replaced the rods and it worked, doe that mean the springs or rod itself wear out too? We are doing a deep clean now, and have also replaced the suspension straps. It works much better with new straps, as one was busted. But is still unbalanced at least once or twice a wash.
- de
Añadir tu respuesta
robyn.holmes estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 14
Ultimos 30 días: 70
Todo El Tiempo: 3,855
