Turning on problem. It self-starts on charger. Boot ONLY with Shift.
Hi,
When I connect the MagSafe charger to the laptop, it turns on by itself. As soon as the Apple logo appears with the loading bar, it turns off and not responding on power button only on MagSafe connection.
When I hold the shift key while powering up it goes into Safe Mode and the laptop doesn't turn off but I need to hold shift button pressed down, if I release the shift in a second the system will turn off again.
Recovery mode also turns off when the logo is loaded. Any idea? Thank you for your reply.
Update (09/01/2022)
I have the idea. Is it possible that Is power button still pressed? And that a reason why it always turn on and in second turn off and only way how to stop shut down is keeping pressed shift?
Because when I'm in the Safe mode and release shift key that show me screen for shutting down options (sleep, shut down, restart,...) And immediately shut down. And not responding startup like before for plug in MagSafe charger only when I disconnect the battery. How can i check it? Is any way?
When I disconnect keyboard while booting, the system works correctly (without keyboard).
Maybe new keyboard will fix it or is there any way to repair stuck power button on current keyboard? Button is not pressed down.
Es esta una buena pregunta?
