Saltar al contenido principal
Lanzado en junio de 2017 como sucesor de Surface Pro 4. También conocido como Microsoft Surface Pro 12.3". Número de modelo: FJT-00001.
Only turns on with the power cable
The issue I have is it only turns on when the power cable is plugged in, if I take it out it turns off immediately. When I plug it in the white light shows on the charger but nothing shows on the screen, it will however power on when I press the power button. I replaced the battery but I still have the same issue. For an hour or so the new battery powered the device but didn’t charge, the back got a little warm and now it only powers up with mains power.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
@coopzzz360 you did check your charging cable to make sure it was okay. You cleaned out the charging port with a few puffs of compressed air or similar? You tried to turn the charging cable over (top to bottom)before you plug it in. If so and it all checks out, you are having trouble with your charging circuit. Next step would be to open it up, take plenty of clear pictures of your motherboard etc. with your QUESTION so we can see what you see. I wonder if there is a chance you got a bad battery. Check the battery connector.
Agregar imágenes a una pregunta existente
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Luke estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 16
Todo El Tiempo: 249
