Saltar al contenido principal
Un PC de escritorio construido a partir de piezas de bricolaje listas para usar, en lugar de uno prefabricado de un fabricante importante. Estos también pueden ser construidos por un IS utilizando piezas listas para usar.
Preguntas 20 Ver todo
Why can’t I get into bios so I can download windows
I can’t get into the bios on my computer. I just finished putting everything together and I can’t get into bios no matter how many times I spam the bios key for my computer after turning it on.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
1 comentario:
Hi @rothtorb,
What is the make and model number of the motherboard?
- de
Agregar un comentario
2 Respuestas
Go to the support page on your motherboard manufacturer’s website, they'll probably have a page that tells you how to enter the BIOS on your motherboard. You should make sure your keyboard is plugged directly into your motherboard and try just plugging your installation media (I'm assuming it's a flashdrive with a Windows ISO flashed onto it) directly into your motherboard.
Fue útil esta respuesta?
Puntuación 0
The main Keys to get to BIOS are going to be Esc, F1, F2, F9,F10 and F12 Sometimes Del. You may have to go to a Boot List and Pick Setup to go to BIOS. If you look the Board up it should tell you what Key it is. Another tick you can use at times is to remove all Boot drives and turn it on sometimes it will ask if you want to go to Setup.
Puntuación 0
Añadir tu respuesta
Torben Rothgeb estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 87
