Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Información de reparación y mantenimiento para la secadora de ropa LG TrueSteam. Números de modelo DLEX3570V, WM3670HRA y DLEX3570W para los colores grafito, rojo y blanco, respectivamente.
CL error code L G front load dryer
CL code stays on. Stands for child lock but my model does not have a button on the panel
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
2 comentarios
My model number is dlex3700v
- de
The clean filter light is on but the code cl is showing
- de
Agregar un comentario
2 Respuestas
Respuesta Más Útil
Hi @coachvic,
What is the model number of the dryer?
If it is a DLEX3570V or DLEX3570W then press and hold the Easy Iron button for 3 seconds to either lock or unlock the controls.
If it is a WM3670HRA then press and hold the Pre Wash child lock button for 3 seconds
Fue útil esta respuesta?
Puntuación 1
Hi @shawn03 ,
Activating the Control Lock Function:
Press and hold the Wrinkle Care button for 3 seconds. The Control Lock icon will be shown in the display and all controls will be disabled except the Power button.
Deactivating the Control Lock Function:
Press and hold the Wrinkle Care button for 3 seconds. Once set, Control Lock remains active until it is manually deactivated. Control Lock must be turned off to run another cycle.
Clean Filter Reminder:
The display will show Clean Filter when the dryer is turned on as a reminder to clean the filter. It turns off
when the Start/Pause button is pressed..
Puntuación 1
1 comentario:
Thank you for your two suggestions on how to turn off the CL feature on my
LG dryer. I was just about ready to pull out, what little hair that I have left.
- de
Añadir tu respuesta
Victor Turselli estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 20
Ultimos 30 días: 78
Todo El Tiempo: 13,482
