SD Memory Card maximum
What is the maximum size SD memory card the Canon PowerShot A580 IS will accept?
Es esta una buena pregunta?
According to the User Manual your camera accepts SD memory card/SDHC memory card/MMC Card/MMCplus card/HC MMC plus card. This means you could probably use a 32GB card. I do believe that most people do not go higher than 8GB to prevent read/write errors and buffer overflow etc.
Fue útil esta respuesta?
My 590 is keeps saying memory card error and won't do anythinng what is the problem?
Hi brianshackelford607,
Have you tried a different SD Card?
Try using a card reader connected to a PC to verify if your SD Card is still OK or if there is a problem with the camera
Ultimas 24 horas: 0
Ultimos 7 días: 16
Ultimos 30 días: 30
Todo El Tiempo: 4,657
