Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Laptop Gateway identificada por el modelo # MT3707
How to replace hard drive
I'm trying to replace the hard drive, but the caddy is stuck on something. Hiw do I get it out without breaking it?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Respuesta Más Útil
With the MT3707 you’ll need to locate an IDE hard drive if my research is correct. As far as I can tell this is straight out of 2001 and shipped with Windows XP, and many of these early XP laptops from 2001-3 use IDE instead of SATA. You cannot find a new IDE hard drive these days unless you:
  • Somehow get very lucky
  • Pay more then you would for a new SATA drive
In this case, your best bet is to either call uncle and buy a more modern laptop - new or used, or buy an M.2 (SATA)>IDE adapter and a 128GB SSD since you don’t need much more for Windows XP. XP does not support TRIM natively, so you will need to TRIM the SSD manually unless you purchase one with firmware level TRIM support that does not depend on the OS to work.
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
Marcus Hollis estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 8
Ultimos 30 días: 30
Todo El Tiempo: 444
