Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Una computadora portátil de propósito general lanzada en 2010 con una pantalla de 15.6 ".
Sound system is broken
My laptop sound won't work. I've disassembled the device and I strongly believe there's a problem with a diode or transistor, and since all sound hardware seems to be on board, I'm probably going to need to replace some of these small parts. Does anybody know of the schematics for this laptop?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Hi,
If your computer is not making any sounds, see the Acer Aspire 5253 Has Volume Control Problems problem page for possible causes and solutions.
Here are the schematics for the motherboard, found from this website.
Go to p.27-28 to find the audio circuits.
Have you checked that the headphone socket is OK and connected properly?
When headphones are plugged into the laptop an internal contact in the headphone socket signals the audio codec IC on the HP_Plug# lead (see p.28) to switch the audio away from the main speakers and connect it to the headphone socket. It may be that the headphone socket is faulty and that the audio output is being permanently directed to the socket but it just doesn’t get through it to the headphones. Worth checking first anyway, if only to eliminate the possibility.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Gabriel Bozza estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 17
Todo El Tiempo: 440
