Questions about how to power on this MacBook (MB466LL/A).
Hi, I had purchased this MacBook secondhand as is, and I wanted to find out what was wrong with it because the seller online had mentioned that it would not turn on, however the charging does seem to work. I don’t have access to a charger in my home, but I will probably borrow a friend's.
Anyway, I have tried resetting the SMC on this to no avail, along with cleaning out the dust and grime from the insides plus reapplying thermal paste to the CPU and GPU, with inconclusive results.
The charging does indeed work, so I assume there is no problem with the battery or the MagSafe port.
One method I did try which got my heart pumping, was shorting (I don’t remember which pins to be exact) specified pins on the keyboard slot on the logic board, because the keyboard’s power button appears to be nonfunctional. This got the fan to spin (at full speed) as I held my tweezers onto the pins. (When I removed my tweezers, the computer would shut off). Nothing would appear on the display, but there was hard drive activity (plus loud fan noise).
Could it be be that the keyboard/upper case needs to be replaced, along with the LCD display?
Tl;dr I’ve tried a couple of methods on how to turn on my secondhand MacBook to no avail. I think I’ve verified the logic board and battery/MagSafe port to be working. Shorting keyboard pins does turn on the computer, but no display or keyboard functionality.
Es esta una buena pregunta?
1 comentario
I haven’t tried that yet, but I will later today!
- de Gabriel Rangel
