Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
El HP Probook 4530s pertenece a una línea de portátiles empresariales fabricados por Hewlett-Packard (HP). Forma parte de la serie S (serie estándar), que consiste en pantallas alimentadas por procesadores Intel.
How much is screen replacement
the screen has black sports which are ink so it needs replacement
but I need a quotation for it
HP Probook4530 G2
Es esta una buena pregunta?
Puntuación 0
1 comentario
Hi @azzy29
It depends....... and where you get the parts from.
some prefer getting from ebay or aliexpress... etc
some prefer to get AS-IS parts, e.g. maybe mainboard is dead but LCD is okay... and do replacement...
normally i would suggest you to strip to the LCD panel and search by part number for accurate results.
- de
Agregar un comentario
2 Respuestas
Solución Elegida
Hi @azzy29 ,
Here’s a link to the service manual for your laptop.
Scroll to p.102 to view the necessary pre-requisite steps and then the procedure to remove/replace the display assembly.
Also on p.102 you will find the part numbers for all the displays that are available for your model.
If you search online using the appropriate part number for your particular model only in the search box of your browser, you will get results for suppliers of the part.
To verify which display assembly part number is the correct one, check on the back of the display panel currently installed in your laptop as it is usually printed there.
Fue útil esta respuesta?
Puntuación 1
Respuesta Más Útil
you can do this your self.
https://goo.gl/doAHd4
Puntuación 1
Añadir tu respuesta
qhawe estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 9
Todo El Tiempo: 416
