Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Portátil con 4 GB de RAM y 500 GB de disco duro. Número de modelo: NE56R49u.
I cannot type numbers
Hello i tried typing numbers, yet its not working,, rather only symbols are working.
I used the set of numbers at the right too yet they didn't work.
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
Hi @odimexy ,
Are all the letters OK or are they showing in upper case (capital letters) only?
If they are in upper case (capitals) only check if there is a Shift key stuck in the operated position as this will affect the numbers above the letters on the keyboard as well.
Have you checked that the Number Lock light is operated on the keyboard?
If not press and release the Number Lock key (the number lock light should come on) and then try the numbers on the keypad.
has any liquid been spilled onto the keyboard at all?
Fue útil esta respuesta?
Puntuación 2
Añadir tu respuesta
Odidi Junior estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 10
Todo El Tiempo: 912
