Why does my controller not charge?
My controller will not charge. Sometimes if you get it just right it will charge for about 4 seconds and then turn back off. What should I do?
Es esta una buena pregunta?
It may just be a battery issue. You can replace the battery with the part below. I also provided a guide on how to replace the battery.
Reemplazo de Batería para DualShock4 (CUH-ZCT1U)
DualShock 4 (JDM-030 and Earlier) Controller Battery
Here’s how you can replace your charge port, if necescery. Choose the right charge port for your model controller
Reemplazo del puerto de carga del DualShock 4
Producto
$8.99
Producto
$5.99
Producto
$6.99
Guía
Dificultad:
Moderado
15 - 30 minutes
Guía
Dificultad:
Moderado
25 - 40 minutes
Fue útil esta respuesta?
Hi @ajcooke01 ,
Not disagreeing with you but the OP states "Sometimes if you get it just right it will charge for about 4 seconds". I'm wondering if the "....get it just right..." relates to the USB cable connection and perhaps it may be a loose or damaged port.
Your thoughts? ;-)
I haven't had time to get around to fixing it but I am going to this weekend. That could be a possibility as well. If you have a link to a guide that might help me with that it would be much appreciated!
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 89
