Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
La próxima generación del Santa Fe 2007 debutó en el Salón Internacional del Automóvil de Norteamérica de 2006 en Detroit.
How to replace radiator
how fixed water tank
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 2
5 comentarios
what year is the santa fe
- de
A 2012 Hyundai Santa Fe, have radiator leak, replaced top hose already, still leaking. Can't find a Youtube video for 2012 Santa Fe.
- de
Just to know how to repaired
- de
How to fix or replace radiator
- de
@Martin Caine
What is the year model of the vehicle?
What's wrong with the radiator?
- de
Agregar un comentario
2 Respuestas
Respuesta Más Útil
Here's a video on how to do it:
https://www.youtube.com/watch?v=apAy-nfb...
Fue útil esta respuesta?
Puntuación 1
1 comentario:
While this video is pretty decent, it's for the 2006 model which has some significant differences. I'll have to verify on a 2009, but IIRC the top core support on the 2007 and later doesn't just pop off with 4 screws as shown here.
- de
@lilirishpol ,
Did you check for any coolant stains around the base or seams of the radiator or around the radiator neck etc?
If around the base of the radiator you may have a leaking radiator core or if on the neck of the radiator, a faulty radiator cap.
Get the cooling system pressure tested to see if the leaks show up.
Puntuación 1
Añadir tu respuesta
daniel paintsil estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 12
Ultimos 30 días: 57
Todo El Tiempo: 11,524
