Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
¿Qué hay dentro de un chip? ¿Cómo funciona? Los chips informáticos también se llaman circuitos integrados, circuitos integrados monolíticos, CI, chips o microchips.
3 phase computer chip
I have just had a conversation with a friend who studied quantum computing. Sadly I have forgotten most of the conversation as it was far beyond my knowledge threshold.
Essentially he was saying was that current tradition computer chips are getting smaller and faster but soon we will hit the limit because as the chips shrink we have to pass less current through them. Here, there will be a trade off of chip performance against size.
So as these don't already exist, there must be a good reason why microprocessors can't be build that run on 3 phase AC rather than traditional single phase. Is this because as I understand it, microprocessors have oscillators inside them to generate their clock cycles, these oscillators wouldn't be changing state, but always be fixed, because of the constant flow of electrons? Without the peaks and troughs of single phase, I would assume an oscillator can not oscillate, is that correct?
My knowledge if electronics is pitiful at best, so there is likely some fundamental reason why this isn't mainstream because in my head, this would allow for potentially three times the computing power compared to a traditional microchip.
Thank you.
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
AC and DC are very different!
Your computer is a DC device on the most part. Yes, it has a clock to set a beat to run things but the circuits them selves are DC. The power supply alters the AC from your outlet to DC. Within your system are crystal isolators which run at very fast frequencies which your system divides down to the time bases it needs.
3 Phase AC, is mostly a transmission system its not used by small appliances (lights, radios, TV's, shavers ...). Yes, larger appliances often use it like air conditioners & stoves.
So far the limits we are facing today is within lithography, the printing of the masking material used to create the circuits. Here the wavelength of light its self effects the making of the smaller circuits.
While I'll agree there is a limit on how small you can make things, computer processors are more than size and speed often its how the process is broken up into smaller chunks to then process in unison across multiple processors.
To help illustrate this lets look at the most powerful computers we have today Top500. Count the cores of processors these bad boys have! Now think what your own super computer you would have at home might be, how many cores do you think you might need?
Where I work we have quite a few Mac Pro systems, our most powerful is a 12 core model which is used for very large CAD drawings. Most of the day it sits idling doing nothing!
Intel has chips with 48 cores running in the lab that could be used in a Mac Pro! So a dual processor Mac Pro could have 96 cores (2 CPU chips) in a few years! Now think would would you need such a powerful system today or even in the future? Doing your taxes in a fraction of a sec. Play 96 different songs at once or watch 96 different vids across your screen? So right now we just don't have the need to go with such powerful systems for us everyday folks. Besides, these are desktop not laptop systems which is what many people want (small portible systems).
So while we are still trying to get smaller chip circuits, the need for them is still a long way away for the average person to need them.
Specialized chips is the next wave, to better process voice commands like 'Siri' being the key one for Macs. Self driving cars for accident avoidance as we have become to distracted with our cellphones! Who knows! Maybe a robot or two at home doing the chores, oops! We have some already! iRobot vacuums.
Fue útil esta respuesta?
Puntuación 4
3 comentarios:
What I do not understand is why they don't make processor bigger with more transistors, because most desktop processors are about 1 1/4 inch square with close to 1 1/2 billion trasistors. But why can't it be 3x3 inches and have 7 billion trasistors?
- de
My understanding is that it has to do with cost (how many dies per wafer), yield (large dies have higher likelihood of problems) and heat (large dies generate tremendous heat).
The other problem right now is the size of the transistors. As we start to get to sub 10nm processes, we are facing challenges due to quantum effects. Essentially, the features of the die are so small that quantum effects start taking a larger role, i.e. the wave function (is the atom really where we think it is) and quantum tunnelling. At larger scales this is not a problem but at these tiny scales, it starts to become important.
- de
We are seeing multichip modules in both desktop and laptop systems. For desktops we have AMD’s Threadripper chip which has two dies in the first generation and the second just coming out now four! But these are more workstation class systems not home systems. In the case of laptops Intel is mounting the CPU and GPU chips into one carrier Haswell was the first.
- de
Añadir tu respuesta
Aileen estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 10
Ultimos 7 días: 17
Ultimos 30 días: 35
Todo El Tiempo: 865
