Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Sucesor del Galaxy Note5, lanzado el 19 de agosto de 2016. El Galaxy Note7 fue retirado oficialmente por Samsung en cooperación con la Comisión de Seguridad de Productos del Consumidor de EE. UU. El 13 de octubre de 2016.
How to fix software update failure?
My phone keeps on restarting after software update for installation, repeatedly.
Tried to press and hold all the buttons to reboot, but nothing works.
Es esta una buena pregunta?
Puntuación 3
Agregar un comentario
1 Respuesta
Solución Elegida
That is a software issue either one of these will work. If you don't want to lose data flash downloaded Samsung firmware from sammobile with the matching model number of your phone located in the battery compartment on a label.
Use the first option as it's most likely going to work anyway and you don't lose your data for doing so.
Option 1:
Use Odin with the phone booted into download mode and plugged in. Instructions on how to use Odin and flash firmware onto phone are on every download page of firmware from sammobile.
Option 2:
If you don't need to backup data use Samsung kies with firmware upgrade and initialization turn the phone off by taking out the battery for a few seconds and putting it back in OR holding the power + volume down + home button for 8-15 seconds.
Then hold the power, volume up and home buttons until the white Samsung splash text pops up and immediately stop holding the power button and keep holding volume up and home.
Then it will boot into the recovery menu. And you can use the power button to select and vol up and down to select in the menu. Select wipe data factory reset and reboot phone from recovery mode.
Fue útil esta respuesta?
Puntuación 3
Añadir tu respuesta
marvinangeloquines estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 17
Todo El Tiempo: 5,888
