Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
El Droid RAZR es un smartphone basado en Android con capacidad 4G LTE diseñado por Motorola.
How to power on
my mobile power is not on i keep my Mobile on charge and when i saw it was not on and the battery were about 2% when i keeped
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
Hi,
First make sure that your charger is connected to a working power outlet.
If it is and your phone is still not charging, try connecting your phone to a working PC with a USB cable and see if it indicates that it is charging. If it does it, indicates that your charger is faulty and needs to be replaced. Let it charge fully before using it.
If it doesn't try a different USB cable, just to be sure.
If it still doesn't, you either have a faulty battery or a faulty charging circuit in the phone. The charger may be OK but you have to wait until the phone / battery is repaired to find out.
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
sanjluhana estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 13
Todo El Tiempo: 249
