How to insert memory card
how to insert memory card
Es esta una buena pregunta?
Hi,
You insert a ''micro SD '' card (up to 32GB) into the slot which is located between the power button and the earphone jack on the left side edge of the tablet as you view it.
Here is a link to show you where it is - about 15-20 seconds into the video, don't miss it https://www.youtube.com/watch?v=glT6IDDu...
Push the micro SD card in until you feel it click (the contacts end of the card goes in first). It goes in easily, not much force is required. If it doesn't go in turn the card over and try again.To remove the card push it in gently and it should spring back out enough for you to grab hold of it.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 10
Todo El Tiempo: 779
1 comentario
- de BOBBY
