Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Modelo A1419 / EMC 2806 / Finales de 2014 o mediados de 2015. 3.3 o 3.5 GHz Core i5 o 4.0 GHz Core i7 (ID iMac15,1); EMC 2834 finales de 2015 / 3.3 o 3.5 GHz Core i5 o 4.0 GHz Core i7 (iMac17,1) Todo con pantallas Retina 5K
Glass Over Screen Broken
is it possible to replace protection glass over the screen ?
thanks for answer
Es esta una buena pregunta?
Puntuación 12
8 comentarios
Please give us the last four figures of your serial number located on the bottom of your stand.
- de
serial #C02NG8ULFY11
ENC # 2806
- de
Apple iMac "Core i5" 3.5 27-Inch (Retina 5K, 2014) Specs
Identifiers: Late 2014 - MF886LL/A - iMac15,1 - A1419 - 2806
- de
Many thanks for your answer
One Ring to rule them all....
when reality reaches fiction
- de
Hi all!
I'm having difficulty determining what replacement glass I would need ... last four of serial is ...GG77 ... it's an early-2015 iMac 21.5" with broken screen glass. Works fine, is actually usable despite the crack across the screen. I don't think it's a Retina display. (I'm considering purchasing the iMac, but a lot depends on being able to replace the glass.)
- de
Mostrar 3 comentarios más
Agregar un comentario
6 Respuestas
Solución Elegida
Apple in its infinite wisdom and cost cutting measures has now fused the glass to the display. So it only comes as a complete unit. Here's how it's replaced: Remplazo de la pantalla del iMac Intel 27" Pantalla Retina 5K
Apple Part #661-00200
Reports have been posted of some that have separated the glass but none repaired successfully.
Most units available in the USA cost around $500. A China seller on eBay has it for $310 + $65 shipping. Warning, check the ratings on these sellers.
Fue útil esta respuesta?
Puntuación 4
1 comentario:
Are you sure about that part number? When I search it I find screens for the older, non-Retina 27" iMac.
- de
For small cracks (as long as there’s no missing piece of glass), I used windshield repair kit for cars, and it made the crack almost invisible. Costs about 10 bucks.
Puntuación 3
4 comentarios:
And it worked for you?
- de
The crack is still kinda visible, but only from certain angle, and only when I'm looking up close.
- de
Wow, that's clever! I'll try it on mine.
- de
I'm really curious about the performance of the glass repair liquid. Is there still a chance to upload a photo? I have a chance to get a cracked screen for a very cheap price of 100 usd. Is it worth it ?
- de
Buying a functional iMac 5K with broken glass right now for a cheap price.
Wondering if anybody has found a glass part anywhere ?
I have a 2011 27in laying around the house, has anybody tried using that one ? Maybe by cutting off the metal parts at the bottom, it could fit ?
Thanks for your help.
Puntuación 1
It can be done, I have done it, I can’t find the actual glass anywhere for purchase, heat and air suction vacuum is the answer.
Puntuación 0
4 comentarios:
Are you using it 'commando' or found glass part somewhere?
- de
Where can the glass be ordered from ?
- de
Hey, can you maybe outline your actions, in order to replicate that procedure? Thinking about doing the same. Did you just heated up the glass with a heat blower and peeled if off from the screen? Were there any remaining glue components on the display? Or was it something more sophisticated?
- de
Please let us know more, I have a 27inch 5k 2017 imac i need to replace the glass on and dont feel like paying $600 for it
- de
Does anyone know if the dimensions of the a1312 glass panel and the the a1419 panel are the same?
Puntuación 0
Could you try fitting the 2011 glass to it and letting us know how the dimensions compare with removing the metal bottom pieces ?
Puntuación 0
Añadir tu respuesta
Alain Buffello estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 9
Ultimos 30 días: 34
Todo El Tiempo: 37,690
