Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Esta tableta fue lanzada por Asus en julio de 2013. El modelo también se conoce como ME173X. La tableta cuenta con una pantalla de 7 pulgadas, una ranura para tarjeta microSD, una ranura MicroUSB y un conector para auriculares.
Droidboot Provision OS screen
When tablet is turned on, it goes to a "Droidboot Provision OS" screen. Lists info on tablet; select; reboot ; a list of commands; last info, "Could not open /sys/devices/virtual/backlight". No buttons work except ON/OFF. What can I do? Thanks.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 16
3 comentarios
have you tried a hard reset? hold power button aqnd volume down together fore 10seconds or so then do it again for 2-3 seconds
- de
how do i solve this problem my tablet is showing this massage 'google play store has juss stopped working, whenever i try to access any application' help please
tina
- de
How do I can return to fabric items?
Actually,when I do that,says that installer device ignored
I don't know what to do
Can you help me?
- de
Agregar un comentario
5 Respuestas
Respuesta Más Útil
Hi
download your firmware file from asus.com.
install fastboot on your computer.
use this command:
fastboot flash update pathOfDownloadedFirmwareFile
All of the your files in tablet will delete.
Fue útil esta respuesta?
Puntuación 3
2 comentarios:
ASUS provide zip file and when we run this command it says missing text files
- de
can you give more detailed information ?
- de
Hi. My tab is Asus memo k011.
when I use this command:
this error appears:
C:\adb>fastboot flash update UL-K011-WW-3.1.23.172-user.zip
target reported max download size of 568967168 bytes
Invalid sparse file format at header magi
error: write_sparse_skip_chunk: don't care size 922051909 is not a multiple of t
he block size 4096
sending sparse 'update' (0 KB)...
he block size 4096
he block size 4096
OKAY [ 0.411s]
writing 'update'...
OKAY [ 0.650s]
finished. total time: 1.064s
what I do?
Puntuación 1
Mei tablet bringt das soeben was tun
Puntuación 0
the screen has stoppet can not be used
hej !
surf platan starter sen det går inte använda skärmen
mvh
Puntuación 0
forgot screen pattern of phone
Puntuación 0
Añadir tu respuesta
linda2222 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 36
Todo El Tiempo: 21,813
