Saltar al contenido principal
Envío gratis en pedidos nacionales de $75 o más
El Acer Chromebook C710-2847 es parte de la línea de netbooks de bajo precio de Acer con el sistema operativo Chrome de Google. Los dispositivos se construyen de forma sencilla y necesitan un solo destornillador para desmontarlos.
Keyboard With Water Involved- Need Help ASAP
My sister spilt water on my acer chromebook. Now when I type it'll mess up. Like 'h' will bring up a '/' and 2 will take you to the beginning of the sentence. My side arrows aren't working at all and I can't even log in at the moment.
Es esta una buena pregunta?
Puntuación 8
11 comentarios
i have a touch screen chromebook and it is malfunctioning with ghost clicking because i have a touch screen chromebook and i went on the google page and it said that water damage might be the problem. But the problem is i don't know how to fix a water damaged device
- de Compartir
i can’t do anything on it in broke and i can’t do my password.
- de Compartir
i spilled ornge juice on it now K and I key is VERY stick and hard to press i dont know what to do AND ITS NEW!!!
- de Compartir
As a temporary work around you could get a Bluetooth keyboard and mouse
- de Compartir
the reason that I'm speaking in to the microphone is because my keyboard don't work I'm a school ChromebookAnd that and that backspace delete delete delete delete nevermind I cannot give this to work but I really need help and I really handsome answer hey so can you please help me how to get bike when I go back to school when they coronavirus it over with covid-1910 mm please can you tell me when you haven't answer to my question I cannot get it my work cuz it's a girl it's a two-sided to spilled water on my Chromebook I'm a come up and oh my gosh this music is getting on my nerves I'm sorry CHRISTUS Health Camaro please help
- de Compartir
Mostrar 6 comentarios más
Agregar un comentario
3 Respuestas
Solución Elegida
Abygail Hicks, disassemble your computer by using these guides. or check this video. Clean all parts with a soft brush and some high grade 90%+ isopropyl alcohol. After you clean the parts, you can either let them air dry or use an oven at a low temperature (no more than 100deg Celsius for 10-20min). It sounds like you will have accidentally shorted out the keyboard and may have to replace it.
Fue útil esta respuesta?
Puntuación 4
1 comentario:
About a week ago, I spilled water on my chromebook keyboard. Now the sound is not working at all. How can I fix this?
- de Compartir
Respuesta Más Útil
DO NOT use a hairdryer as it will drive the water deeper. Open the machine and get the keyboard away from the logic board then dry it.
Puntuación 6
Turn off your Chromebook and disconnect power cord. Keep it facing down (to help water/moisture get out). In addition, you can use a hair dryer to blow at the keyboard, while it faces down. But do not let the hair dryer get too close to the keyboard. For example, keep a distance of 4-6 inches. Typically, 10-15 min is sufficient. Then wait for another 10-15min. Plug back the power cord and turn it on. It should work fine. If not, repeat the procedure 2 - 3 times.
Puntuación 3
Añadir tu respuesta
Abygail Hicks estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 31
Todo El Tiempo: 21,782
