Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Guías de reparación, desmontaje e información de resolución de problemas para la segunda generación de Apple iPad con red celular 3G CDMA (Verizon), disponible con 16, 32 o 64 GB de almacenamiento. Cuenta con un procesador de dos-núcleos A5. Lanzado en marzo de 2011. Identificado por el número de modelo A1397. Las reparaciones requieren el uso de calor y una cuidadosa palanca.
ipad 2 not activating error
This is sorta a follow up to a previous question I had asked.(Replaced digitizer and antennas, still searching..)
None of the previous problems were fixed btw.
So we were instructed to restore the ipad to factory. Now we are getting the:
"Your iPad could not be activated because the activation server is temporarily unavailable. Try connecting your iPad to iTUnes to activate it, or try again in a couple of minutes.
If this problem persists, contact Apple Support at apple.com/support"
What do?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 5
1 comentario
Mine to just after updating to 9.3 - totally bricked my iPad2
- de
Agregar un comentario
5 Respuestas
Respuesta Más Útil
I would check for damage in the flex between the main board and the cell service board
Fue útil esta respuesta?
Puntuación 1
1 comentario:
Hi Jessa,
Vortex's comment below seems to describe the problem I'm having on an iPad 4 which came to me for a battery replacement, it was re-booting every couple minutes.. New battery - No Change, Log files report temperature sensor failure on sensors 0,6 & 1. iPad wont Activate, displays "searching"
Question : if I can find someone that can replace the base band chip, will it function as normal..
Many Thanks
Paul
- de
look into log files..
I think baseband temperature sensor fails working causing the part to shutdown, causing the device to reset, and so on
see also Nathan Rakes post, which ist the effect caused by this
Puntuación 1
I have seen this error many times on iphones with broken baseband chip after water damage or impact damages.
Itunes trying to read device's baseband chip (IMEI number or something like that) to activate the phone.
I guess same thing happening to your ipad CDMA. Baseband chip looks like not functioning.
Reasons
1- If its water damaged try to clean mainboard shortcuts and resolder corroded components.
2- if it has impact damaged, using hot air on the baseband chip may bring the baseband function back. I dont know What temperature and howmany minutes. But you can google for it.
Good luck ...
Puntuación 0
Hi.
How can i check the flex between board and cell service board?
I mean, if i check bouth sides of the flex i have continuty, but how can i check if the pads are soldered well?
Thanks?
Puntuación 0
What i want to do with my Ipad 2? Activation server is unavailable?
Puntuación 0
Añadir tu respuesta
Nathan Rakes estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 30
Todo El Tiempo: 7,255
