Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Flash does not work!
Turned camera on and heard a loud pop. Removed and charged NP-BG1 battery. Reinstalled charged battery, but battery discharged rapidly. Bought new NP-FG1 battery, charged battery, installed battery and got "E91:01 error code with flash symbol flashing on LCD screen. Camera takes pictures, but flash does not flash. I suspect the capacitor blew when the loud pop was heard. Any suggestions?
Where can I buy a replacement capacitor without buying the entire flash unit?
THANKS in advance.
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
Dick, the error code that you are getting is related to an issue with the flash or light on your camera. There are a two things that may have made that noise, Either your flash bulb, or your flash capacitor. Follow [http://he error code that you are getting is related to an issue with the flash or light on your camera. It's usually just replacing the flash bulb on the camera,|this guide] to either replace the capacitor or the whole assembly. the part numbers are as follows:
1-479-663-31 FLASH UNIT
1-112-819-11 ELECT 97uF 315V Capacitor
you can get it from here
A-1231-877-A ST-133 BOARD, COMPLETE
Imagen
Hope this helps, good luck.
Fue útil esta respuesta?
Puntuación 2
3 comentarios:
THANKS "oldturkey03", I plan to disassemble the camera and investigate further this week. Dick
- de
На плате st-133 посмотри контакты конденсатора и детали которая распаяна под лампой . Может и в самом конденсаторе дело ! Тратить надо ...
- de
сперва саму батарею проверь . а потом дальше ...
- de
Añadir tu respuesta
Dickie estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 9
Ultimos 30 días: 28
Todo El Tiempo: 2,210
