Saltar al contenido principal
Samsung Galaxy Watch4 Classic Battery Replacement
Qué necesitas
  1. Samsung Galaxy Watch4 Classic Battery Replacement, Power down your watch: paso 1, imagen 1 de 1
    • Before starting repairs, take your watch off the charger and power it down.
    • Remove the watch band.
  2. Samsung Galaxy Watch4 Classic Battery Replacement, Unscrew the back cover: paso 2, imagen 1 de 1
    • Use a Tri-point Y00 screwdriver to remove the four 4.0 mm-long screws securing the back cover.
  3. Samsung Galaxy Watch4 Classic Battery Replacement, Pry open the back cover: paso 3, imagen 1 de 2 Samsung Galaxy Watch4 Classic Battery Replacement, Pry open the back cover: paso 3, imagen 2 de 2
    • Insert an opening tool into the seam between the back cover and the metal housing.
    • Twist the opening tool to create a gap.
    • Don't try to remove the back cover all the way yet. The sensor flex cable is still connected to the motherboard.
  4. Samsung Galaxy Watch4 Classic Battery Replacement, Disconnect the sensor flex cable: paso 4, imagen 1 de 2 Samsung Galaxy Watch4 Classic Battery Replacement, Disconnect the sensor flex cable: paso 4, imagen 2 de 2
    • Lay the watch face down.
    • Carefully swing open the back cover by folding it to the opposite site of the created gap.
    • Use the flat end of a spudger to pry up and disconnect the sensor flex cable from the motherboard.
  5. Samsung Galaxy Watch4 Classic Battery Replacement, Remove the back cover: paso 5, imagen 1 de 1
    • Remove the back cover.
    • Make sure the rubber gasket is undamaged. If damaged, replace it with a new one during reassembly to maintain proper water resistance.
  6. Samsung Galaxy Watch4 Classic Battery Replacement, Disconnect the hall sensor flex cable: paso 6, imagen 1 de 2 Samsung Galaxy Watch4 Classic Battery Replacement, Disconnect the hall sensor flex cable: paso 6, imagen 2 de 2
    • Use the pointed end of a spudger to disconnect the hall sensor flex cable.
  7. Samsung Galaxy Watch4 Classic Battery Replacement, Disconnect the display flex cable: paso 7, imagen 1 de 2 Samsung Galaxy Watch4 Classic Battery Replacement, Disconnect the display flex cable: paso 7, imagen 2 de 2
    • Use a spudger to disconnect the display flex cable.
  8. Samsung Galaxy Watch4 Classic Battery Replacement, Disconnect the side buttons: paso 8, imagen 1 de 2 Samsung Galaxy Watch4 Classic Battery Replacement, Disconnect the side buttons: paso 8, imagen 2 de 2
    • Use a spudger to disconnect the crown button flex cable.
  9. Samsung Galaxy Watch4 Classic Battery Replacement, Unscrew the motherboard: paso 9, imagen 1 de 1
    • Use a Phillips screwdriver to remove the 4.4 mm-long screw securing the motherboard.
  10. Samsung Galaxy Watch4 Classic Battery Replacement, Remove the motherboard: paso 10, imagen 1 de 3 Samsung Galaxy Watch4 Classic Battery Replacement, Remove the motherboard: paso 10, imagen 2 de 3 Samsung Galaxy Watch4 Classic Battery Replacement, Remove the motherboard: paso 10, imagen 3 de 3
    • Use your fingers to lift the motherboard out from the watch assembly towards the bottom of the watch.
    • During reassembly, make sure none of the flex cables become trapped underneath the motherbaord.
  11. Samsung Galaxy Watch4 Classic Battery Replacement, Lever up the battery: paso 11, imagen 1 de 3 Samsung Galaxy Watch4 Classic Battery Replacement, Lever up the battery: paso 11, imagen 2 de 3 Samsung Galaxy Watch4 Classic Battery Replacement, Lever up the battery: paso 11, imagen 3 de 3
    • The battery is held in place with light adhesive.
    • Place the flat end of a spudger in the small gap between the plastic frame and the battery, opposite to the display cable.
    • Carefully lever the battery up and out of its recess.
    • Take care not to puncture or bend the battery with your tool—a punctured or bent battery may leak dangerous chemicals or cause a thermal event.
    • Don't try to remove the battery completely yet, as its connector is still adhered to the core assembly.
  12. Samsung Galaxy Watch4 Classic Battery Replacement, Remove the battery: paso 12, imagen 1 de 2 Samsung Galaxy Watch4 Classic Battery Replacement, Remove the battery: paso 12, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Lift the battery up a little in order to access its glued down connector cable.
    • Use a pair of blunt tweezers to lift up the battery connector which is secured with some light adhesive.
    • You will most likely be able to re-use the adhesive to fix the new battery in place. If not, replace it with double sided or pre-cut adhesive tape.
    • Remove the battery.
Conclusión
If possible, turn on your device and test your repair before installing new adhesive and resealing.
Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the device at the places where the old adhesive was located, not directly onto the battery. Press the new battery firmly into place.
For optimal performance, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least 2 more hours. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
11 personas más completaron esta guía.
Adriana Zwink
Miembro Desde 12/18/19
48,810 Reputación
167 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
136 Miembros
17,449 Guías creadas
3 comentarios
What kind of battery does it use?
Dylan - Contestar
The directions are perfect! I had very little issue following your instructions.
One point I would make is that there seems to be more of an available gap to pry the back off of the watch located between the pairs of wristband spurs where there is very little gap on the sides. After almost 20 minutes of trying to get the little plastic tool to work the back off, I looked closely at the area between the spurs and it looked more promising. A couple of probes with the tool, and the the back started right off. The rest is history. Thanks!!!
Rufus T. Montgomery - Contestar
Is there any adhesive applied for the water resistance while installation of the battery ?
Wasabi - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 21
Ultimos 7 días: 143
Ultimos 30 días: 479
Todo El Tiempo: 8,455
