Introducción
Follow this guide to remove and replace the battery on a Motorola Edge.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
In this guide, some photos show the daughterboard and vibrator removed, but they don't need to be removed in order to replace the battery.
For your safety, discharge the battery below 25% before disassembling your phone.
This reduces the risk of fire if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
Qué necesitas
Heat an iOpener, then apply it along the bottom edge of the back cover for two minutes.
Apply a suction cup to the back of the phone, as close to the center of the bottom edge as possible.
Pull up on the suction cup with strong, steady force to create a gap between the back cover and the frame.
Insert an opening pick into the gap.
Slide the pick back and forth along the bottom edge to slice through the adhesive.
Leave the pick in to prevent the adhesive from resealing.
Apply a heated iOpener to the back cover's right edge for two minutes.
Rotate the opening pick around the bottom-right corner of the phone.
Insert a new opening pick into the gap you just created.
Slide the pick along the right edge of the phone to separate the adhesive.
Repeat the heating, slicing, and leaving opening picks for the remaining edges of the device.
Remove the back cover, taking care not to damage the components inside the phone.
Use a T5 Torx screwdriver to remove the twelve 3.4 mm-long screws securing the motherboard cover.
Herramienta utilizada en este paso:Tweezers$4.99
Use a pair of blunt tweezers or your fingers to lift up and remove the motherboard cover.
Use a spudger to pry up and disconnect the battery cable's press connector from the motherboard.
Use a T5 Torx screwdriver to remove the nine 3.4 mm screws securing the daughterboard.
Use a spudger to pry up the plastic daughterboard cover and disconnect it from the rest of the phone.
Use a spudger to pry up and disconnect the interconnect cable's press connector from the motherboard.
Use a spudger to pry up and disconnect the interconnect cable's press connector from the daughterboard.
Use your fingers to remove the interconnect cable after it has been disconnected from both the motherboard and daughterboard.
Heat an iOpener and place it on the screen for two minutes in order to loosen the adhesive on the battery.
Wedge the pointed end of an opening pick between the right side of the battery and the midframe.
Herramienta utilizada en este paso:Plastic Cards$2.99
After making a gap between the battery and the frame, replace the opening pick with a plastic card.
Carefully slide a plastic card underneath the battery to cut through the adhesive.
Slide a plastic card under the battery, then carefully lift the battery up until the adhesive is loose enough to remove the battery.
For optimal performance, calibrate your newly installed battery after completing this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
