Saltar al contenido principal
Reemplazo de pantalla de Google Pixel 8 Pro
Aviso: Ahora estás editando un requisito previo de la guía que estabas viendo. Cualquier cambio que realices afectará a todas las 14 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 22
Paso 22
Google Pixel 8 Pro Screen Replacement, Reassembly information: paso 0, imagen 1 de 3 Google Pixel 8 Pro Screen Replacement, Reassembly information: paso 0, imagen 2 de 3 Google Pixel 8 Pro Screen Replacement, Reassembly information: paso 0, imagen 3 de 3
  • If you're installing a new screen with pre-installed adhesive, follow this step during reassembly. Otherwise, follow this guide to apply adhesive to your old screen.
  • Thoroughly check the entire screen for any plastic liners or tape and use the pull tabs to remove all of them. Look carefully for a large piece of plastic covering the back of the screen, a small one near the front camera cutout, and adhesive liners around the perimeter.
  • Reconnect the screen cable and reinstall its cover.
  • This is a good point to test your phone before sealing it up. Temporarily power on your phone and make sure it works as expected. Power it down before continuing.
  • Firmly press the screen into place on the frame—you should feel the clips "pop" into place.
  • Press firmly around the perimeter of the screen to secure it with the new adhesive.
  • Optionally, you can strengthen the adhesive bond by applying pressure evenly to the phone.
  • Follow this guide to calibrate the fingerprint sensor.
Si estás instalando una nueva pantalla con adhesivo pre-instalado, sigue este paso durante el rearmado. De lo contrario, sigue esta guía para aplicar adhesivo a tu pantalla original.
Revisa bien toda la pantalla para ver si hay algún plástico protector o cinta adhesiva y usa las lengüetas para quitarlos todos. Busca con atención un trozo grande de plástico que cubre la parte posterior de la pantalla, uno pequeño cerca del recorte de la cámara frontal y adhesivos protectores alrededor del perímetro.
Reconecta el cable de la pantalla y vuelve a colocar su cubierta.
Este es un buen punto para probar tu teléfono antes de sellarlo. Enciende tu teléfono temporalmente y asegúrate que funciona según lo esperado. Apágalo antes de continuar.
Firmemente presiona la pantalla en su lugar en el marco. Deberías escuchar a los clips colocarse en su lugar.
Presiona firmemente alrededor del perímetro de la pantalla para asegurarla con el nuevo adhesivo.
Opcionalmente, puedes reforzar la unión del adhesivo aplicando presión uniformemente al teléfono.
Sigue esta guía para calibrar el sensor de huella dactilar.
