Saltar al contenido principal
Sustitución del conjunto del chasis central de una Xbox Series X
Aviso: Estás editando una guía de requisitos previos. Cualquier cambio que realices afectará a todas las 17 guías que incluyen este paso.
Inglés
Español
Paso 2
Xbox Series X Center Chassis Assembly Replacement: paso 0, imagen 1 de 2 Xbox Series X Center Chassis Assembly Replacement: paso 0, imagen 2 de 2
  • Use a pair of tweezers to pull up on the black plastic pull tab to disconnect the USB port cable.
  • Pull only on the pull tab, not the cable itself.
  • If the USB port cable feels adhered to the metal chassis, use an apply an iOpener or hair dryer to heat the cable. Depending on your model of Xbox, you may also need to slide an opening pick under the cable to separate the adhesive.
Utiliza un par de pinzas sin punta para tirar hacia arriba de la pestaña de plástico negro y así desconectar el cable del puerto USB.
Tira solamente de la lengüeta, no del cable.
Si notas que el cable del puerto USB está adherido al chasis de metal, aplica un iOpener o caliéntalo con cuidado con un secador de pelo, para ablandar el adhesivo.
-[* black] Use a pair of [product|IF145-020|tweezers] to pull up on the black plastic pull tab to disconnect the USB port cable.
+[* black] Use a pair of tweezers to pull up on the black plastic pull tab to disconnect the USB port cable.
[* icon_caution] Pull only on the pull tab, not the cable itself.
- [* icon_note] If the USB port cable feels adhered to the metal chassis, [guide|11677|apply an iOpener|new_window=true] or carefully heat it with a hair dryer to soften the adhesive.
+ [* icon_note] If the USB port cable feels adhered to the metal chassis, use an [guide|11677|apply an iOpener|new_window=true] or [guide|157348|hair dryer|new_window=true] to heat the cable. Depending on your model of Xbox, you may also need to slide an opening pick under the cable to separate the adhesive.
