Saltar al contenido principal
Demontage van de MacBook Pro 16" 2019
Inglés
Holandés
Paso 12
MacBook Pro 16" 2019 Teardown: paso 0, imagen 1 de 3 MacBook Pro 16" 2019 Teardown: paso 0, imagen 2 de 3 MacBook Pro 16" 2019 Teardown: paso 0, imagen 3 de 3
  • Now that all our keyboard questions are laid to rest, we can move on to the rest of the bits still lying around.
  • First up, these fancy new XL-Earpods speakers with an extended enclosure, and opposed woofers on the top and bottom.
  • The opposed woofers are supposed to cancel each other's vibration out. Kinda like the anti-noise feature of the new AirPods Pro, but ... with bass. Anti-bass?
  • We aren't as sure about the elongated enclosure, but our best guess is that the new shape redirects sound to improve its quality. Maybe extra volume was needed to accommodate the second woofer?
  • Next, another sound upgrade: a "high performance" three-mic array. It's laid out similarly to the three-mic array in the 2018 MacBook Air, but looks a little beefier, which could mean these are higher-quality mics.
  • Finally, the lithium powerhouse that's probably drawing a suspicious glare from the FAA: Apple's 99.8 Wh battery (11.36 V, 8790 mAh).
  • That's the largest battery we've ever seen in a MacBook—a 4.8 Wh increase over the 17" MacBook Pro, and a huge 16.2 Wh increase over the latest 15" MacBook Pro.
  • Where did this extra capacity come from? Here, Apple pulled an iPhone 11—each battery cell looks identical to its predecessor, but measures 0.8 mm thicker on average.
Nu dat al onze toetsenbordvragen zijn behandeld, kunnen we door met de rest van de onderdelen.
Als eerste nemen we deze fancy nieuwe XL-earpods speakers met vergrote behuizing en tegenovergestelde speakers aan de boven- en onderkant.
De tegenovergestelde speakers zijn zo geplaatst om elkaars trillingen te reduceren. Dit lijkt een beetje op de anti-ruis feature van de nieuwe AirPods Pro, maar... met bass. Anti-bass?
We weten niet helemaal zeker waarom de behuizing verlengd is, maar onze gok is dat de nieuwe vorm het geluid zo beter geleidt en dus verbetert. Wellicht was een beetje extra volume ook nodig om een tweede speaker te kunnen behuizen.
Vervolgens, nog een geluidsverbetering: een drievoudige "high-performance" microfoonopstelling. Deze liggen in eenzelfde soort opstelling als die in de MacBook Air versie uit 2018, maar deze lijken iets dikker, wat zou kunnen duiden op kwalitatief betere microfoons.
Ten slotte, de lithium krachtpatser waar je het vliegtuig niet zomaar mee in zou komen: Apple's 99.8 Wh batterij (11.36 V, 8790 mAh).
Dit is de grootste batterij die we ooit hebben gezien in een MacBook - een toename van 4.8 Wh ten opzichte van de 17" MacBook Pro en een enorme toename van 16.2 Wh ten opzichte van de meest recente versie van de 15" MacBook Pro.
Waar komt deze extra capaciteit vandaan? Hier kun je zien hoe Apple de batterijcapaciteit van een iPhone 11 verbeterde - iedere cel lijkt precies op die van haar voorganger behalve dat deze gemiddeld 0.8 mm dikker is.
