Saltar al contenido principal
Reemplazo del cristal trasero del Samsung Galaxy S8+
Aviso: Estás editando una guía de requisitos previos. Cualquier cambio que realices afectará a todas las 5 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 11
Paso 11
Samsung Galaxy S8+ Back Glass Replacement: paso 0, imagen 1 de 1
  • Remove the back cover.
  • To install a new back cover:
  • Use tweezers to peel away any remaining adhesive from the phone's chassis. Then clean the adhesion areas with high concentration isopropyl alcohol (at least 90%) and a lint-free cloth to prep the surface for the new adhesive.
  • Peel the adhesive backing off of the new rear glass, carefully line up one edge of the glass against the phone chassis, and firmly press the glass onto the phone.
  • To reinstall the back cover, or to install a back cover without pre-installed adhesive, follow this guide.
  • Be sure to turn on your phone and test your repair before installing new adhesive and resealing the phone.
  • If desired, you may reinstall the back cover without replacing the adhesive. Remove any large chunks of adhesive that might prevent the back cover from sitting down flush. After installation, heat the back cover and apply pressure to secure it. It won't be waterproof, but the glue is usually more than strong enough to hold.
  • You may also need to transfer the camera bezel to your new part. If that's the case, follow our camera bezel replacement guide.
Remueve la tapa trasera.
Para volver a instalar la tapa trasera:
Usa pinzas para despegar cualquier resto de adhesivo del chasis del teléfono. Luego limpia las áreas de adhesión con alcohol isopropílico de alta concentración (al menos 90 %) y un paño sin pelusa para preparar la superficie para el nuevo adhesivo.
Despega el adhesivo del vidrio trasero nuevo, alinea con cuidado un borde del vidrio contra el chasis del teléfono y presiona firmemente el vidrio contra el teléfono.
Para volver a instalar la tapa trasera, o para instalar una tapa trasera sin adhesivo preinstalado, sigue esta guía.
Asegúrate de encender tu teléfono y probar la reparación antes de instalar adhesivo nuevo y volver a sellar el teléfono.
Puedes volver a instalar la cubierta posterior sin reemplazar el adhesivo. Quita cualquier trozo grande de adhesivo que impida que la tapa trasera quede nivelada. Después, calienta la tapa trasera y aplica presión para asegurarla. No será resistente al agua, pero el pegamento suele ser lo suficientemente fuerte como para sostenerlo.
Es posible que también debas transferir el bisel de la cámara a su nueva pieza. Si ese es el caso, sigue nuestra guía de reemplazo del bisel de la cámara.
