Saltar al contenido principal
TicWatch Pro 3 GPS Motherboard Replacement
Qué necesitas
  1. TicWatch Pro 3 GPS Motherboard Replacement, Power down your watch: paso 1, imagen 1 de 2 TicWatch Pro 3 GPS Motherboard Replacement, Power down your watch: paso 1, imagen 2 de 2
    • Before starting repairs, take your watch off the charger and power it down.
    • Remove the watch band.
  2. TicWatch Pro 3 GPS Motherboard Replacement, Unfasten the back cover: paso 2, imagen 1 de 1
    • Use a Torx T3 screwdriver to remove the four 4.1 mm-long screws securing the back cover.
  3. TicWatch Pro 3 GPS Motherboard Replacement, Loosen the back cover adhesive: paso 3, imagen 1 de 1
    • Apply a heated iOpener to the rear side of the watch for 5 minutes to loosen the adhesive underneath.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device.
  4. TicWatch Pro 3 GPS Motherboard Replacement, Pry up the back cover assembly: paso 4, imagen 1 de 3 TicWatch Pro 3 GPS Motherboard Replacement, Pry up the back cover assembly: paso 4, imagen 2 de 3 TicWatch Pro 3 GPS Motherboard Replacement, Pry up the back cover assembly: paso 4, imagen 3 de 3
    • Insert the flat end of a spudger into the microphone opening at the top edge of the back cover.
    • Pry upwards to loosen the back cover assembly. This may require some force.
    • Don't try to remove the back cover assembly all the way yet. It's still connected to the daughterboard.
    • Swing the back cover assembly open by 45 degrees to gain access to the sensor assembly cable.
  5. TicWatch Pro 3 GPS Motherboard Replacement, Disconnect the sensor assembly cable: paso 5, imagen 1 de 2 TicWatch Pro 3 GPS Motherboard Replacement, Disconnect the sensor assembly cable: paso 5, imagen 2 de 2
    • Use a spudger to disconnect the sensor assembly cable by prying the connector straight up from its socket.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  6. TicWatch Pro 3 GPS Motherboard Replacement, Remove the back cover assembly: paso 6, imagen 1 de 3 TicWatch Pro 3 GPS Motherboard Replacement, Remove the back cover assembly: paso 6, imagen 2 de 3 TicWatch Pro 3 GPS Motherboard Replacement, Remove the back cover assembly: paso 6, imagen 3 de 3
    • Remove the back cover assembly.
  7. TicWatch Pro 3 GPS Motherboard Replacement, Disconnect the microphone cable: paso 7, imagen 1 de 2 TicWatch Pro 3 GPS Motherboard Replacement, Disconnect the microphone cable: paso 7, imagen 2 de 2
    • Use a spudger to disconnect the microphone cable by prying the connector straight up from its socket.
  8. TicWatch Pro 3 GPS Motherboard Replacement, Unfasten the core assembly: paso 8, imagen 1 de 1
    • Use a Phillips screwdriver to remove the three 4.1 mm-long screws securing the core assembly.
  9. TicWatch Pro 3 GPS Motherboard Replacement, Pry up the core assembly: paso 9, imagen 1 de 2 TicWatch Pro 3 GPS Motherboard Replacement, Pry up the core assembly: paso 9, imagen 2 de 2
    • Insert the point of a spudger between the right edge of the core assembly and the watch frame.
    • Pry upwards to loosen the core assembly.
    • Don't try to remove the core assembly all the way yet. It's still connected to the screen.
  10. TicWatch Pro 3 GPS Motherboard Replacement, Swing open the core assembly: paso 10, imagen 1 de 3 TicWatch Pro 3 GPS Motherboard Replacement, Swing open the core assembly: paso 10, imagen 2 de 3 TicWatch Pro 3 GPS Motherboard Replacement, Swing open the core assembly: paso 10, imagen 3 de 3
    • Carefully swing open the core assembly like the front cover of a book.
    • Avoid straining or tearing the display cables at the bottom of the core assembly.
  11. TicWatch Pro 3 GPS Motherboard Replacement, Disconnect the display cables: paso 11, imagen 1 de 3 TicWatch Pro 3 GPS Motherboard Replacement, Disconnect the display cables: paso 11, imagen 2 de 3 TicWatch Pro 3 GPS Motherboard Replacement, Disconnect the display cables: paso 11, imagen 3 de 3
    • Use a spudger to disconnect the screen and the digitizer cables by prying the connectors straight up from their sockets.
  12. TicWatch Pro 3 GPS Motherboard Replacement, Remove the core assembly: paso 12, imagen 1 de 2 TicWatch Pro 3 GPS Motherboard Replacement, Remove the core assembly: paso 12, imagen 2 de 2
    • Remove the core assembly.
  13. TicWatch Pro 3 GPS Motherboard Replacement, Disconnect the interconnect cable: paso 13, imagen 1 de 2 TicWatch Pro 3 GPS Motherboard Replacement, Disconnect the interconnect cable: paso 13, imagen 2 de 2
    • Use a spudger to disconnect the interconnect cable by prying the connector straight up from its socket.
  14. TicWatch Pro 3 GPS Motherboard Replacement, Remove the daughterboard: paso 14, imagen 1 de 2 TicWatch Pro 3 GPS Motherboard Replacement, Remove the daughterboard: paso 14, imagen 2 de 2
    Herramienta utilizada en este paso:
    • Use a pair of tweezers to remove the daughterboard.
  15. TicWatch Pro 3 GPS Motherboard Replacement, Pry up the battery: paso 15, imagen 1 de 2 TicWatch Pro 3 GPS Motherboard Replacement, Pry up the battery: paso 15, imagen 2 de 2
    • The battery is held in place by mild adhesive.
    • Insert the flat end of a spudger between the bottom edge of the battery and the midframe.
    • Take care not to puncture or bend the battery with your tool—a punctured or bent battery may leak dangerous chemicals or cause a fire.
    • Pry upwards to loosen the battery.
    • If you're struggling to pry up the battery, place a heated iOpener onto the motherboard to loosen the adhesive underneath. Don't apply the iOpener directly onto the battery.
    • Don't try to remove the battery all the way yet. It's still connected to the motherboard.
  16. TicWatch Pro 3 GPS Motherboard Replacement, Reposition the battery: paso 16, imagen 1 de 2 TicWatch Pro 3 GPS Motherboard Replacement, Reposition the battery: paso 16, imagen 2 de 2
    • Carefully fold the battery over to gain access to the battery cable connector.
    • Avoid straining or tearing the battery cable.
  17. TicWatch Pro 3 GPS Motherboard Replacement, Disconnect the battery: paso 17, imagen 1 de 2 TicWatch Pro 3 GPS Motherboard Replacement, Disconnect the battery: paso 17, imagen 2 de 2
    • Use a spudger to disconnect the battery cable by prying the connector straight up from its socket.
  18. TicWatch Pro 3 GPS Motherboard Replacement, Remove the battery: paso 18, imagen 1 de 2 TicWatch Pro 3 GPS Motherboard Replacement, Remove the battery: paso 18, imagen 2 de 2
    • Remove the battery.
    • Do not reinstall a damaged or deformed battery, as doing so is a potential safety hazard.
    • Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the device at the places where the old adhesive was located, not directly onto the battery. Press the new battery firmly into place.
  19. TicWatch Pro 3 GPS Motherboard Replacement, Remove the interconnect cable: paso 19, imagen 1 de 2 TicWatch Pro 3 GPS Motherboard Replacement, Remove the interconnect cable: paso 19, imagen 2 de 2
    • Remove the interconnect cable.
  20. TicWatch Pro 3 GPS Motherboard Replacement, Pry up the motherboard: paso 20, imagen 1 de 2 TicWatch Pro 3 GPS Motherboard Replacement, Pry up the motherboard: paso 20, imagen 2 de 2
    • Insert the point of a spudger between the midframe and the motherboard.
    • Pry upwards to loosen the motherboard.
  21. TicWatch Pro 3 GPS Motherboard Replacement, Remove the motherboard: paso 21, imagen 1 de 2 TicWatch Pro 3 GPS Motherboard Replacement, Remove the motherboard: paso 21, imagen 2 de 2
    • Remove the motherboard.
Conclusión
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
During reassembly, apply new adhesive where it's necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
For optimal performance, calibrate your newly installed battery after completing this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our TicWatch Pro 3 answers community for help.
3 personas más completaron esta guía.
Dominik Schnabelrauch
Miembro Desde 11/23/16
229,498 Reputación
682 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
118 Miembros
19,455 Guías creadas
5 comentarios
Hi there , just disassembled the motherboard no issues, i wanted to see what was wrong with the watch and its atleast from what i can tell water damage to the motherboard, can anyone help me find a replacement ? I'm struggling with that
iballisticgiannakos - Contestar
Hi, have you found a replacement? The second display is the one that is failing for me. Thank you.
Walter Guerrero -
IP68 ... haha. Also water damage here. It's so small, that I needed to remove the mainboard to finally see it.
This is the 2nd TicWatch that was failing...
Any idea where to get a proper and working replacement motherboard? Ebay has a few, but that are all marked as "defective" --> useless.
Alex C. - Contestar
This fixed the small dark spot near the seconds digits (Essential mode). Some said it was a expanded battery, but upon disassembly the battery was still completely flat, so no dice there. However, I've reassembled the watch with all screws loosely tightened and it fixed it. Of course not waterproof anymore, but at least the display won't damage itself now. The spot disappeared completely.
Valentino - Contestar
I have 2 tw pro 3 . 1st one water damaged cause 2nd display not to work and watch goes into freeze mode . The 2nd tw motherboard completely dead . Struggling to find motherboards for these watches . Any suggestions?
Rashied Johnson - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 13
Ultimos 30 días: 50
Todo El Tiempo: 1,579
