Saltar al contenido principal
Samsung Galaxy S10e Fingerprint Sensor Replacement
Qué necesitas
  1. Samsung Galaxy S10e Fingerprint Sensor Replacement, Heat the back cover: paso 1, imagen 1 de 1
    • Opening your phone will compromise its waterproof seals. Have replacement adhesive ready before you proceed, or take care to avoid liquid exposure if you reassemble your phone without replacing the adhesive.
    • Turn your phone off completely before you begin this repair.
    • Prepare an iOpener and heat the back of the phone along the right edge for about two minutes. This will help soften the adhesive securing the back cover.
    • You may need to reheat and reapply the iOpener several times to get the phone warm enough. Follow the iOpener instructions to avoid overheating.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the OLED display and internal battery are both susceptible to heat damage.
  2. Samsung Galaxy S10e Fingerprint Sensor Replacement, Prepare to slice the adhesive: paso 2, imagen 1 de 2 Samsung Galaxy S10e Fingerprint Sensor Replacement, Prepare to slice the adhesive: paso 2, imagen 2 de 2
    • In the following steps, you'll be cutting through the adhesive securing the back cover.
    • The adhesive is laid out as seen in the first image, which shows the inside of the cover after it has been removed.
    • As seen from the outside of the phone, you'll be slicing through the adhesive in the highlighted areas.
    • The adhesive is the thinnest on the right side of the phone, just below the Bixby button.
  3. Samsung Galaxy S10e Fingerprint Sensor Replacement, Secure a suction cup: paso 3, imagen 1 de 2 Samsung Galaxy S10e Fingerprint Sensor Replacement, Secure a suction cup: paso 3, imagen 2 de 2
    • Secure a suction cup to the back cover, as close to the heated edge as possible, just under the Bixby button where the adhesive is thinnest.
    • The suction cup will not make a good seal on the curved portion of the glass, so avoid putting it on the very edge.
    • If the phone's back cover is cracked, the suction cup may not stick. Try lifting it with strong tape, or superglue the suction cup in place and allow it to cure so you can proceed.
  4. Samsung Galaxy S10e Fingerprint Sensor Replacement, Create an opening gap: paso 4, imagen 1 de 3 Samsung Galaxy S10e Fingerprint Sensor Replacement, Create an opening gap: paso 4, imagen 2 de 3 Samsung Galaxy S10e Fingerprint Sensor Replacement, Create an opening gap: paso 4, imagen 3 de 3
    • Prop up the heated edge of the phone on something that is about 0.5 inches (13 mm) thick. This will angle the phone so that the opening tool is easier to insert.
    • Lift the back cover's right edge with your suction cup, opening a slight gap between the back cover and the frame.
    • This may require a significant amount of force. If you have trouble, apply more heat to further soften the adhesive, and try again. The adhesive cools very fast, so you may need to heat it repeatedly.
    • If you're using an iOpener, follow the heating instructions to avoid overheating it, or the gel pack may burst.
    • Press the edge of an opening tool into the gap.
    • The rear glass can break if you use too much force or attempt to pry with metal tools.
  5. Samsung Galaxy S10e Fingerprint Sensor Replacement: paso 5, imagen 1 de 3 Samsung Galaxy S10e Fingerprint Sensor Replacement: paso 5, imagen 2 de 3 Samsung Galaxy S10e Fingerprint Sensor Replacement: paso 5, imagen 3 de 3
    • Slide the opening tool along the right edge of the phone to slice through the adhesive securing the back cover.
  6. Samsung Galaxy S10e Fingerprint Sensor Replacement: paso 6, imagen 1 de 2 Samsung Galaxy S10e Fingerprint Sensor Replacement: paso 6, imagen 2 de 2
    • Insert an opening pick into the edge next to the opening tool. Leave the pick here to prevent the separated glue from re-adhering.
  7. Samsung Galaxy S10e Fingerprint Sensor Replacement: paso 7, imagen 1 de 1
    • Apply a heated iOpener to the top edge of the phone for two minutes.
  8. Samsung Galaxy S10e Fingerprint Sensor Replacement: paso 8, imagen 1 de 3 Samsung Galaxy S10e Fingerprint Sensor Replacement: paso 8, imagen 2 de 3 Samsung Galaxy S10e Fingerprint Sensor Replacement: paso 8, imagen 3 de 3
    • Insert an opening pick near the top right corner of the phone and slide it around the corner and across the top edge of the phone.
    • The glued area is larger here, so you'll need to insert your pick farther into the phone to separate it.
    • Leave the opening pick in place to prevent the adhesive from re-adhering.
  9. Samsung Galaxy S10e Fingerprint Sensor Replacement: paso 9, imagen 1 de 1
    • Apply a heated iOpener to the left edge of the phone for two minutes.
  10. Samsung Galaxy S10e Fingerprint Sensor Replacement: paso 10, imagen 1 de 3 Samsung Galaxy S10e Fingerprint Sensor Replacement: paso 10, imagen 2 de 3 Samsung Galaxy S10e Fingerprint Sensor Replacement: paso 10, imagen 3 de 3
    • Insert a new opening pick near the top left corner and slide it along the left edge of the phone.
    • Again, leave the opening pick in place in the left edge of the phone to prevent the adhesive from resealing.
  11. Samsung Galaxy S10e Fingerprint Sensor Replacement: paso 11, imagen 1 de 1
    • Apply a heated iOpener to the bottom edge of the phone for two minutes.
  12. Samsung Galaxy S10e Fingerprint Sensor Replacement: paso 12, imagen 1 de 3 Samsung Galaxy S10e Fingerprint Sensor Replacement: paso 12, imagen 2 de 3 Samsung Galaxy S10e Fingerprint Sensor Replacement: paso 12, imagen 3 de 3
    • Insert an opening pick near a bottom corner of the phone, and slide it along the bottom edge of the phone to separate the adhesive there.
    • The glued area is larger here, so you'll need to insert your pick farther into the phone to fully separate it.
  13. Samsung Galaxy S10e Fingerprint Sensor Replacement: paso 13, imagen 1 de 3 Samsung Galaxy S10e Fingerprint Sensor Replacement: paso 13, imagen 2 de 3 Samsung Galaxy S10e Fingerprint Sensor Replacement: paso 13, imagen 3 de 3
    • Use the opening picks to very carefully pry up the back cover.
    • If you encounter any resistance, stop prying and use an opening pick to cut any remaining adhesive.
    • Remove the back cover.
  14. Samsung Galaxy S10e Fingerprint Sensor Replacement: paso 14, imagen 1 de 1
    • Follow this guide to reinstall the back cover and replace the adhesive.
    • Be sure to turn on your phone and test your repair before installing new adhesive and resealing the phone.
    • If desired, you may reinstall the back cover without replacing the adhesive. Remove any large chunks of adhesive that might prevent the back cover from sitting down flush. After installation, heat the back cover and apply pressure to secure it. It won't be waterproof, but the leftover adhesive is usually more than strong enough to hold.
  15. Samsung Galaxy S10e Fingerprint Sensor Replacement, Remove the midframe: paso 15, imagen 1 de 1
    • Remove the eight 3.9 mm Phillips screws securing the upper midframe to the phone.
  16. Samsung Galaxy S10e Fingerprint Sensor Replacement: paso 16, imagen 1 de 2 Samsung Galaxy S10e Fingerprint Sensor Replacement: paso 16, imagen 2 de 2
    • Slide an opening pick under the bottom right corner of the upper midframe to separate the adhesive holding it to the lower midframe.
  17. Samsung Galaxy S10e Fingerprint Sensor Replacement: paso 17, imagen 1 de 2 Samsung Galaxy S10e Fingerprint Sensor Replacement: paso 17, imagen 2 de 2
    • Insert the point of a spudger in the small cutout on the right edge of the plastic part of the upper midframe, near the Bixby button.
    • Use the point of the spudger to pry the midframe up from the phone chassis.
  18. Samsung Galaxy S10e Fingerprint Sensor Replacement: paso 18, imagen 1 de 1
    • Lift the midframe by the plastic section and remove it from the phone.
    • To reinstall, first insert the top edge of the assembly into the phone's frame, and then gently press down on the rest of the assembly to snap it into place.
  19. Samsung Galaxy S10e Fingerprint Sensor Replacement, Disconnect the battery: paso 19, imagen 1 de 2 Samsung Galaxy S10e Fingerprint Sensor Replacement, Disconnect the battery: paso 19, imagen 2 de 2
    • Use the flat end of a spudger to pry the battery connector straight up from its socket and disconnect it.
  20. Samsung Galaxy S10e Fingerprint Sensor Replacement, Remove the loudspeaker: paso 20, imagen 1 de 1
    • Use a Phillips driver to remove the seven 3.9 mm screws securing the loudspeaker.
  21. Samsung Galaxy S10e Fingerprint Sensor Replacement: paso 21, imagen 1 de 2 Samsung Galaxy S10e Fingerprint Sensor Replacement: paso 21, imagen 2 de 2
    • Insert the point of a spudger into the notch on the right edge of the loudspeaker.
    • Pry up with the spudger to loosen the loudspeaker.
  22. Samsung Galaxy S10e Fingerprint Sensor Replacement: paso 22, imagen 1 de 3 Samsung Galaxy S10e Fingerprint Sensor Replacement: paso 22, imagen 2 de 3 Samsung Galaxy S10e Fingerprint Sensor Replacement: paso 22, imagen 3 de 3
    • Lift the loudspeaker up and remove it.
    • To reassemble, press the loudspeaker edges until it snaps into place.
  23. Samsung Galaxy S10e Fingerprint Sensor Replacement, Disconnect the screen: paso 23, imagen 1 de 2 Samsung Galaxy S10e Fingerprint Sensor Replacement, Disconnect the screen: paso 23, imagen 2 de 2
    • Use the flat end of a spudger to pry up and disconnect the screen connector from its motherboard socket.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  24. Samsung Galaxy S10e Fingerprint Sensor Replacement, Disconnect the fingerprint sensor: paso 24, imagen 1 de 2 Samsung Galaxy S10e Fingerprint Sensor Replacement, Disconnect the fingerprint sensor: paso 24, imagen 2 de 2
    • Use the point of a spudger to pry up and disconnect the fingerprint sensor connector from its motherboard socket.
  25. Samsung Galaxy S10e Fingerprint Sensor Replacement, Remove the fingerprint sensor bracket: paso 25, imagen 1 de 1
    • Use a Phillips driver to remove the two 4 mm screws securing the fingerprint sensor bracket.
  26. Samsung Galaxy S10e Fingerprint Sensor Replacement: paso 26, imagen 1 de 1
    • Apply a heated iOpener to the fingerprint sensor bracket for one minute to loosen the adhesive.
  27. Samsung Galaxy S10e Fingerprint Sensor Replacement: paso 27, imagen 1 de 3 Samsung Galaxy S10e Fingerprint Sensor Replacement: paso 27, imagen 2 de 3 Samsung Galaxy S10e Fingerprint Sensor Replacement: paso 27, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • The fingerprint sensor bracket is held in place with very strong adhesive.
    • Use the points of your tweezers to slowly pry up the fingerprint sensor bracket.
    • If the bracket won't budge, apply more heat and try again.
    • Remove the fingerprint sensor bracket.
  28. Samsung Galaxy S10e Fingerprint Sensor Replacement, Loosen the fingerprint sensor cable: paso 28, imagen 1 de 2 Samsung Galaxy S10e Fingerprint Sensor Replacement, Loosen the fingerprint sensor cable: paso 28, imagen 2 de 2
    • Use a pair of tweezers to loosen the fingerprint sensor cable from the adhesive gasket.
  29. Samsung Galaxy S10e Fingerprint Sensor Replacement, Slice through the screen adhesive: paso 29, imagen 1 de 3 Samsung Galaxy S10e Fingerprint Sensor Replacement, Slice through the screen adhesive: paso 29, imagen 2 de 3 Samsung Galaxy S10e Fingerprint Sensor Replacement, Slice through the screen adhesive: paso 29, imagen 3 de 3
    • Flip the phone over so that the display is facing up.
    • Apply a heated iOpener to the right edge of the screen for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the internal battery is susceptible to heat damage.
    • As you wait, note the following seams:
    • Display seam—this seam sits above the thin plastic bezel. You need to pry along this seam to separate the display.
    • Frame seam—this seam sits below the thin plastic bezel. Do not pry along this seam or you will damage the plastic bezel.
  30. Samsung Galaxy S10e Fingerprint Sensor Replacement: paso 30, imagen 1 de 3 Samsung Galaxy S10e Fingerprint Sensor Replacement: paso 30, imagen 2 de 3 Samsung Galaxy S10e Fingerprint Sensor Replacement: paso 30, imagen 3 de 3
    • Apply a suction cup to the heated edge of the display.
    • Pull up on the suction up with strong, steady force to create a gap.
    • Depending on the age of your device, this may be difficult. If you have trouble, apply more heat and try again.
    • Insert the point of an opening pick into the display seam gap.
    • Make sure to insert the opening pick into the seam above the plastic bezel.
  31. Samsung Galaxy S10e Fingerprint Sensor Replacement: paso 31, imagen 1 de 3 Samsung Galaxy S10e Fingerprint Sensor Replacement: paso 31, imagen 2 de 3 Samsung Galaxy S10e Fingerprint Sensor Replacement: paso 31, imagen 3 de 3
    • Slide the opening pick along the right edge to slice through the adhesive.
    • Leave the opening pick in the corner to prevent the adhesive from resealing.
  32. Samsung Galaxy S10e Fingerprint Sensor Replacement: paso 32, imagen 1 de 1
    • Apply a heated iOpener to the bottom edge of the display for one minute.
  33. Samsung Galaxy S10e Fingerprint Sensor Replacement: paso 33, imagen 1 de 2 Samsung Galaxy S10e Fingerprint Sensor Replacement: paso 33, imagen 2 de 2
    • Slide an opening pick along the bottom edge to slice through the adhesive.
  34. Samsung Galaxy S10e Fingerprint Sensor Replacement: paso 34, imagen 1 de 3 Samsung Galaxy S10e Fingerprint Sensor Replacement: paso 34, imagen 2 de 3 Samsung Galaxy S10e Fingerprint Sensor Replacement: paso 34, imagen 3 de 3
    • Repeat the heating and slicing procedure for the remaining display sides.
  35. Samsung Galaxy S10e Fingerprint Sensor Replacement, Remove the display glass: paso 35, imagen 1 de 2 Samsung Galaxy S10e Fingerprint Sensor Replacement, Remove the display glass: paso 35, imagen 2 de 2
    • Lift up and remove the display glass.
    • The OLED panel is normally sealed against this glass panel. Once it's exposed to air, the panel will no longer work.
  36. Samsung Galaxy S10e Fingerprint Sensor Replacement, Remove the display panel: paso 36, imagen 1 de 1
    • Apply a heated iOpener to the OLED panel for a minute to soften up the panel adhesive.
  37. Samsung Galaxy S10e Fingerprint Sensor Replacement: paso 37, imagen 1 de 2 Samsung Galaxy S10e Fingerprint Sensor Replacement: paso 37, imagen 2 de 2
    • Lift the display panel from the right edge and peel it away from the frame.
  38. Samsung Galaxy S10e Fingerprint Sensor Replacement: paso 38, imagen 1 de 2 Samsung Galaxy S10e Fingerprint Sensor Replacement: paso 38, imagen 2 de 2
    • Thread the display panel connector through the frame.
    • If you are having trouble, you can choose to cut the display panel cable in order to remove the display.
  39. Samsung Galaxy S10e Fingerprint Sensor Replacement: paso 39, imagen 1 de 2 Samsung Galaxy S10e Fingerprint Sensor Replacement: paso 39, imagen 2 de 2
    • Remove the display panel.
    • If you are using a custom-cut adhesive, follow this guide for instructions on how to remove the old adhesive and attach the replacement screen.
    • If you are using Tesa tape to reattach the screen, follow this guide.
  40. Samsung Galaxy S10e Fingerprint Sensor Replacement, Remove the fingerprint sensor: paso 40, imagen 1 de 3 Samsung Galaxy S10e Fingerprint Sensor Replacement, Remove the fingerprint sensor: paso 40, imagen 2 de 3 Samsung Galaxy S10e Fingerprint Sensor Replacement, Remove the fingerprint sensor: paso 40, imagen 3 de 3
    • Use the flat end of a spudger to pry up the fingerprint cable cover from the frame.
    • Remove the fingerprint cable cover.
  41. Samsung Galaxy S10e Fingerprint Sensor Replacement: paso 41, imagen 1 de 3 Samsung Galaxy S10e Fingerprint Sensor Replacement: paso 41, imagen 2 de 3 Samsung Galaxy S10e Fingerprint Sensor Replacement: paso 41, imagen 3 de 3
    • Use the point of a spudger to gently pull the fingerprint sensor cable through its frame cutout.
  42. Samsung Galaxy S10e Fingerprint Sensor Replacement: paso 42, imagen 1 de 2 Samsung Galaxy S10e Fingerprint Sensor Replacement: paso 42, imagen 2 de 2
    Comprar
  43. Samsung Galaxy S10e Fingerprint Sensor Replacement: paso 43, imagen 1 de 2 Samsung Galaxy S10e Fingerprint Sensor Replacement: paso 43, imagen 2 de 2
    • Remove the fingerprint sensor from its recess.
Conclusión
After you've completed the repair, follow this guide to test your repair.
Una persona más ha completado esta guía.
Arthur Shi
Miembro Desde 01/03/18
258,910 Reputación
531 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
140 Miembros
18,067 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 30
Ultimos 30 días: 164
Todo El Tiempo: 4,860
