Saltar al contenido principal
Samsung Galaxy A53 5G Fingerprint Sensor Replacement
Qué necesitas
  1. Samsung Galaxy A53 5G Fingerprint Sensor Replacement, Heat the back cover: paso 1, imagen 1 de 1
    • Prepare an iOpener and apply it to the back cover for at least two minutes to loosen the adhesive underneath.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  2. Samsung Galaxy A53 5G Fingerprint Sensor Replacement, Insert an opening pick: paso 2, imagen 1 de 2 Samsung Galaxy A53 5G Fingerprint Sensor Replacement, Insert an opening pick: paso 2, imagen 2 de 2
    • Secure a suction handle to the right edge of the back cover, as close to the edge as possible.
    • Lift the back cover with the suction handle to create a small gap between the back cover and the frame.
    • In case you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Insert an opening pick into the gap you created.
  3. Samsung Galaxy A53 5G Fingerprint Sensor Replacement, Slice the adhesive: paso 3, imagen 1 de 3 Samsung Galaxy A53 5G Fingerprint Sensor Replacement, Slice the adhesive: paso 3, imagen 2 de 3 Samsung Galaxy A53 5G Fingerprint Sensor Replacement, Slice the adhesive: paso 3, imagen 3 de 3
    • Slide the opening pick to the top right corner to slice the adhesive.
    • Leave the opening pick in place to prevent the adhesive from resealing.
  4. Samsung Galaxy A53 5G Fingerprint Sensor Replacement, Slice the adhesive: paso 4, imagen 1 de 3 Samsung Galaxy A53 5G Fingerprint Sensor Replacement, Slice the adhesive: paso 4, imagen 2 de 3 Samsung Galaxy A53 5G Fingerprint Sensor Replacement, Slice the adhesive: paso 4, imagen 3 de 3
    • Insert a second opening pick at the top right edge of your phone.
    • Slide the opening pick to the bottom right corner to slice the adhesive.
    • Leave the opening picks in place to prevent the adhesive from resealing.
  5. Samsung Galaxy A53 5G Fingerprint Sensor Replacement: paso 5, imagen 1 de 3 Samsung Galaxy A53 5G Fingerprint Sensor Replacement: paso 5, imagen 2 de 3 Samsung Galaxy A53 5G Fingerprint Sensor Replacement: paso 5, imagen 3 de 3
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener for one to two minutes to reheat it.
    • Insert a third opening pick at the bottom right corner of your phone.
    • Slide the opening pick along the bottom edge of your phone to slice the adhesive.
    • Leave the opening pick in the bottom left corner to prevent the adhesive from resealing.
  6. Samsung Galaxy A53 5G Fingerprint Sensor Replacement: paso 6, imagen 1 de 3 Samsung Galaxy A53 5G Fingerprint Sensor Replacement: paso 6, imagen 2 de 3 Samsung Galaxy A53 5G Fingerprint Sensor Replacement: paso 6, imagen 3 de 3
    • Insert a fourth opening pick at the bottom left corner of your phone.
    • Slide the opening pick along the left edge to slice the adhesive.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
  7. Samsung Galaxy A53 5G Fingerprint Sensor Replacement: paso 7, imagen 1 de 2 Samsung Galaxy A53 5G Fingerprint Sensor Replacement: paso 7, imagen 2 de 2
    • Insert a fifth opening pick at the top left corner.
    • Slide the opening pick along the top edge of the back cover to slice the remaining adhesive.
  8. Samsung Galaxy A53 5G Fingerprint Sensor Replacement, Remove the back cover: paso 8, imagen 1 de 1
    • Remove the back cover.
    • Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
    • Secure the new back cover with pre-cut adhesive or double-sided adhesive tape. After installing the back cover, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond—a stack of heavy books works well.
  9. Samsung Galaxy A53 5G Fingerprint Sensor Replacement, Unscrew the motherboard cover: paso 9, imagen 1 de 1
    • Use a Phillips screwdriver to remove the eight 3.9 mm-long screws securing the motherboard cover.
  10. Samsung Galaxy A53 5G Fingerprint Sensor Replacement, Pry up the motherboard cover: paso 10, imagen 1 de 3 Samsung Galaxy A53 5G Fingerprint Sensor Replacement, Pry up the motherboard cover: paso 10, imagen 2 de 3 Samsung Galaxy A53 5G Fingerprint Sensor Replacement, Pry up the motherboard cover: paso 10, imagen 3 de 3
    • Insert the flat end of an spudger into the gap between the frame and the motherboard cover on the right edge.
    • Use the spudger to pry up the motherboard cover.
  11. Samsung Galaxy A53 5G Fingerprint Sensor Replacement, Remove the motherboard cover: paso 11, imagen 1 de 1
    • Remove the motherboard cover.
  12. Samsung Galaxy A53 5G Fingerprint Sensor Replacement, Disconnect the battery cable: paso 12, imagen 1 de 2 Samsung Galaxy A53 5G Fingerprint Sensor Replacement, Disconnect the battery cable: paso 12, imagen 2 de 2
    • Use a spudger to disconnect the battery cable by prying the connector straight up from its socket.
  13. Samsung Galaxy A53 5G Fingerprint Sensor Replacement, Unfasten the loudspeaker screws: paso 13, imagen 1 de 1
    • Use a Phillips screwdriver to remove the seven 3.9 mm-long screws securing the loudspeaker assembly.
  14. Samsung Galaxy A53 5G Fingerprint Sensor Replacement, Remove the loudspeaker: paso 14, imagen 1 de 3 Samsung Galaxy A53 5G Fingerprint Sensor Replacement, Remove the loudspeaker: paso 14, imagen 2 de 3 Samsung Galaxy A53 5G Fingerprint Sensor Replacement, Remove the loudspeaker: paso 14, imagen 3 de 3
    • Insert the flat end of a spudger into the gap between the right edge of the loudspeaker assembly and the midframe.
    • Use your spudger to pry up the loudspeaker assembly.
    • Remove the loudspeaker assembly.
  15. Samsung Galaxy A53 5G Fingerprint Sensor Replacement, Heat the fingerprint sensor: paso 15, imagen 1 de 1
    • The fingerprint sensor of the Galaxy A53 5G is held in place by adhesive.
    • Prepare an iOpener and apply it to the display for at least two minutes to loosen the adhesive underneath.
  16. Samsung Galaxy A53 5G Fingerprint Sensor Replacement, Disconnect the fingerprint sensor: paso 16, imagen 1 de 2 Samsung Galaxy A53 5G Fingerprint Sensor Replacement, Disconnect the fingerprint sensor: paso 16, imagen 2 de 2
    • Use the flat end of a spudger to disconnect the fingerprint sensor from the daughterboard.
  17. Samsung Galaxy A53 5G Fingerprint Sensor Replacement, Remove the fingerprint sensor: paso 17, imagen 1 de 3 Samsung Galaxy A53 5G Fingerprint Sensor Replacement, Remove the fingerprint sensor: paso 17, imagen 2 de 3 Samsung Galaxy A53 5G Fingerprint Sensor Replacement, Remove the fingerprint sensor: paso 17, imagen 3 de 3
    Herramienta utilizada en este paso:
    • Use the flat end of a spudger to pry the fingerprint sensor straight out of its socket.
    • Use a pair of tweezers or your fingers to remove the fingerprint sensor.
Conclusión
4 personas más completaron esta guía.
Adriana Zwink
Miembro Desde 12/18/19
56,747 Reputación
167 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
Miembros de 118
19,648 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 48
Ultimos 30 días: 153
Todo El Tiempo: 3,373
